I have been running Ubuntu 14.04 on my desktop for a year now. Today, I got Windows 7 and installed it on a separate drive with the Ubuntu drive removed. Now I can boot each OS by interrupting the BIOS and changing the boot order, so I know both bootloaders work, but when I ran sudo update-grub and sudo udpate-grub2, Windows was not listed. What can I do to add Windows to grub?
- 327
Try to locate and mount the Windows partition first, then run sudo update-grub.
For example,
sudo fdisk -l
results
/dev/sda1 2048 53035007 53032960 25.3G 83 Linux
/dev/sda2 53035008 99139583 46104576 22G 83 Linux
/dev/sda3 99139584 141266943 42127360 20.1G 83 Linux
/dev/sda4 * 141266944 215681023 74414080 35.5G 7 HPFS/NTFS/exFAT
in this case the Windows partition is /dev/sda4 (because of NTFS Type and because I know it). Then,
sudo mount /dev/sda4 /mnt
and then
sudo update-grub
Windows entry in grub.cfg is nothing special. It is just a chainloader entry. If above method fails to identify Windows properly, then you can manually add the entry in /etc/grub.d/40_custom file.
Example of Windows 40_custom entry for MBR (not GPT)
menuentry "Windows 7 64bit" --class windows --class os {
insmod part_msdos
insmod ntfs
set root='hd0,msdos4'
chainloader +1
What matters here is the set root parameter. hd0,msdos4 = /dev/sda4. If you have more than one HDDs then it might be hd1,msdos4 = /dev/sdb4.
If you follow the manual method, don't forget to run sudo update-grub after editing the 40_custom file.
- 17,865
- 6
- 57
- 66
