I have Dell Vostro 3443 laptop. It has a certified pre-install Ubuntu 12.04.2 LTS 64-bit by manufacturer. I have quite lot of software on it, updated using update manager. Now when I try to install wine and gnome it says broken packages, below is shows the logs generated by command line install.
$ sudo apt-get install gnome
[sudo] password for mithun:
Reading package lists... Done
Building dependency tree
 gnome : Depends: gnome-core (= 1:3.0+6ubuntu3) but it is not going to be installed
         Depends: alacarte (>= 0.13.2) but it is not going to be installed
         Depends: cheese (>= 3.0) but it is not going to be installed
         Depends: evolution (>= 3.0) but it is not installable
         Depends: evolution-plugins (>= 3.0) but it is not installable
         Depends: hamster-applet (>= 2.91.2) but it is not going to be installed
         Depends: tomboy (>= 1.6) but it is not going to be installed or
                  gnote but it is not going to be installed
         Depends: vinagre (>= 3.0) but it is not going to be installed
         Depends: gimp (>= 2.6) but it is not going to be installed
         Depends: inkscape (>= 0.48) but it is not going to be installed
         Depends: simple-scan but it is not going to be installed
         Depends: epiphany-extensions (>= 3.0) but it is not going to be installed
         Depends: gedit-plugins (>= 3.0) but it is not going to be installed
         Depends: gnome-applets (>= 2.91) but it is not going to be installed
         Recommends: browser-plugin-gnash but it is not going to be installed
         Recommends: gdebi but it is not going to be installed
         Recommends: gnome-games-extra-data (>= 3.0) but it is not going to be installed
         Recommends: liferea but it is not installable or
                     evolution-rss but it is not going to be installed or
                     blam but it is not going to be installed
         Recommends: menu-xdg but it is not going to be installed
and for the case of wine it will give as
$ sudo apt-get install wine
 openssh-client : Depends: adduser (>= 3.10) but it is not going to be installed
                  Depends: passwd
 ssh : Depends: openssh-server
 wine : Depends: wine1.6 but it is not going to be installed or
                 wine1.7 but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
and tried to install dependencies on my own. And followed this source.
Plus the command:
$ dpkg --get-selections | grep deinstall
give the following list:
colord                      deinstall
cups                        deinstall
dell-eula                   deinstall
dell-recovery-bootloader            deinstall
deluge                      deinstall
deluge-gtk                  deinstall
dmraid                      deinstall
firstboot-video2                deinstall
hplip                       deinstall
indicator-printers              deinstall
kpartx-boot                 deinstall
libblas3gf                  deinstall
libboost-filesystem1.46.1           deinstall
libboost-python1.46.1               deinstall
libboost-system1.46.1               deinstall
libboost-thread1.46.1               deinstall
libdebconfclient0               deinstall
libdebian-installer4                deinstall
libdmraid1.0.0.rc16             deinstall
libevent-core-2.0-5             deinstall
libevent-openssl-2.0-5              deinstall
libgfortran3                    deinstall
libgl1-mesa-glx                 deinstall
libglapi-mesa                   deinstall
liblapack3gf                    deinstall
libmikmod2                  deinstall
libopts25                   deinstall
libportmidi0                    deinstall
libsane                     deinstall
libsdl-mixer1.2                 deinstall
libsdl-ttf2.0-0                 deinstall
libsmpeg0                   deinstall
libtorrent-rasterbar6               deinstall
libxatracker1                   deinstall
oem-config                  deinstall
oem-config-gtk                  deinstall
oobe-dim-disable                deinstall
printer-driver-gutenprint           deinstall
quilt                       deinstall
sane-utils                  deinstall
shotwell                    deinstall
user-setup                  deinstall
xserver-xorg                    deinstall
xserver-xorg-core               deinstall
xserver-xorg-video-intel            deinstall
xserver-xorg-video-openchrome           deinstall
xserver-xorg-video-vmware           deinstall
I removed them using:
$ dpkg --purge `dpkg --get-selections | grep deinstall | cut -f1`
and tried to do update again still no use. The problem remains, am I missing any thing.
Edit : 2
Later it end up in complete os crash - not able to get log page also
The following are clear by now:
  1. The manufacturer has given the ubuntu version as such - i.e., no modification. But with few additional packages.
  2. The factory reset option is available(which I used later), but only available after system test for hardware done. Still don't know the reason for such behavior.
  3. Even after factory reset cannot able to install wine.
Mithun B
  • 151
try sudo apt-get update && sudo apt-get upgrade
and now try the following:
sudo apt-get install -f packagename
#Please change the package name accordingly.
I hope this will help as -f option fix the broken packages for you. Good luck!
