I was unable to setup nut on a server for the UPS Eaton 5E with USB connection. All results what did I get was that driver is not running and UPS is not recognized. What kind of driver is suitable for me and what kind of settings? Unit is Eaton 5E.
result of $ lsusb -v
Bus 004 Device 007: ID 0463:ffff MGE UPS Systems UPS
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 8
idVendor 0x0463 MGE UPS Systems
idProduct 0xffff UPS
bcdDevice 0.01
iManufacturer 1
iProduct 2
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 34
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 20mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 3 Human Interface Device
bInterfaceSubClass 0 No Subclass
bInterfaceProtocol 0 None
iInterface 0
HID Device Descriptor:
bLength 9
bDescriptorType 33
bcdHID 1.10
bCountryCode 33 US
bNumDescriptors 1
bDescriptorType 34 Report
wDescriptorLength 549
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 20
Device Status: 0x0001
Self Powered
Content of /etc/nut/ups.conf
[Eaton5E]
driver = blazer_usb
port = auto
Result of $ upsdrvctl start for usbhid-ups driver:
Network UPS Tools - UPS driver controller 2.4.3
Network UPS Tools - Generic HID driver 0.34 (2.4.3)
USB communication driver 0.31
No matching HID UPS found
Driver failed to start (exit status=1)
Result of $ upsdrvctl start for blazer_usb driver:
Network UPS Tools - Megatec/Q1 protocol USB driver 0.03 (2.4.3)
No supported devices found. Please check your device availability with 'lsusb'
and make sure you have an up-to-date version of NUT. If this does not help,
try running the driver with at least 'subdriver', 'vendorid' and 'productid'
options specified. Please refer to the man page for details about these options
(man 8 blazer).
Update: I tried to connect a desktop linux Xubuntu 12.04, which detected the UPS and UPS vendor via usbhid-ups driver, but did not detected any battery state and shows battery as discharged (what is not true, server is running on it several minutes with no troubles) and fiel technology as Unknown.
