You can safely unmount and spin-down an external hard disk from the terminal most easily by using the command-line functionality of udisks, which does not require the use of sudo if your system is set up correctly. (To list your device names, enter mount in the terminal first.)
When you have found your external drive, use the following commands. You must first unmount the partition (use sdb1 or whatever mount showed as the location):
udisks --unmount /dev/sdb1
Then to safely remove (i.e. spindown- you will hear it click and spin-down), use only sdb, for example:
udisks --detach /dev/sdb
NOTE: It is of crucial importance here that you use sdb or sdc without a partition number when using the detach option; i.e. sdb1 or sdc1 will not work. The partition must be unmounted first and then the disk itself spun down as the examples show.
The udisks commands work successfully for all my pata and sata external hard disks.
