-1
I am aware that it's a common problem but i am quite new with linux systems and I would like to know how to exactly fix my problem.
youtube-to-mp3: Depends: libc6 (>= 2.14) ale 2.19-0ubuntu6.4 is to be installed
                Depends: libgcc1 (>= 1:4.1.1) ale 1:4.9.1-0ubuntu1 is to be installed
                Depends: libqt4-declarative (>= 4:4.7.0~rc1) ale 4:4.8.5+git192->g085f851+dfsg-2ubuntu4 is to be installed
                Depends: libqt4-network (>= 4:4.6.1) ale 4:4.8.5+git192->g085f851+dfsg-2ubuntu4 is to be installed
                Depends: libqtcore4 (>= 4:4.8.0) ale 4:4.8.5+git192-g085f851+dfsg->2ubuntu4 is to be installed
                Depends: libqtgui4 (>= 4:4.8.0) ale 4:4.8.5+git192-g085f851+dfsg->2ubuntu4 is to be installed
                Depends: libstdc++6 (>= 4.6) ale 4.8.2-19ubuntu1 is to be installed
                Depends: libav-tools (>= 4:0.8.6-0ubuntu0.12.04.1) ale 7:2.5->0ppa1~trusty is to be installed
                Depends: libavcodec-extra-53 (>= 4:0.8.6ubuntu0.12.04.1) but will not be installed
                Depends: libmp3lame0 (>= 3.99.3+repack1-1) ale 3.99.5+repack1->3ubuntu1 is to be installed
I know that I need somehow delete some of those libraries but I don't know which and how.
Would be really nice if you guys could help. The error appeared when I stopped the installation process of one of the applications because it got stuck.
Eliah Kagan
  • 119,640
Zwierzak
  • 173
To remove unresolved packages take a look here
Here is how I installed youtube-to-mp3. Download your preferred architecture 32bit or 64bit.
Once downloaded, just press Ctrl+Alt+T on your keyboard to open Terminal. When it opens, navigate to where the file was downloaded, probably the downloads folder, and run the command(s) below:
sudo dpkg -i <file_name>.deb
Or you can use Gdebi to install it.
This will install the latest version (3.6) of youtube-to-mp3
Mitch
  • 109,787
The OP posted this solution as an edit (reproduced here with minor copy editing).
First I tried to type in the terminal:
sudo apt-get clean
sudo apt-get autoclean
sudo apt-get install -f
This didn't work. Then I tried
sudo apt-get autoremove
which also didn't work.
Finally thanks to kindness of people here this code worked:
sudo add-apt-repository 'http://www.mediahuman.com/packages/ubuntu'
sudo apt-key adv --keyserver pgp.mit.edu --recv-keys D808832C7D19F1F3
sudo apt-get update
sudo apt-get install youtube-to-mp3
Eliah Kagan
  • 119,640
