This problem follows on from 14.04: No Auto login at User Account settings - I am administrator (see all comments)
I tried to remove encryption via this link How can I enable autologin for my user account when the option is not there?
but when I tried:
$ mv -rf /home/user
mv: invalid option -- 'r'
after that I was getting cannot remove [etc...] Read Only file system.
I skipped over what couldn't be done and went straight to trying to rm /home/user/.ecryptfs. Finished, rebooted, and now the login screen is stuck on the password login screen
I went here and tried this Login screen loops unless you login as Guest
I inputted command sudo mv .Xauthority .XauthorityBak which resulted in
mv: cannot stat 'X.authority': No such file or directory
I tried
$ mount -rw -o remount /home/[username]
mount: only root can do that
I tried the second answer here Ubuntu gets stuck in a login loop
$ ls -lah
total 8.OK
dr-x------ 2 [username username] 4.OK Dec 15 2014 .
drwxr-xr-x 6 root root 4. OK Dec 15 00:10 ..
lrwxrwxrwx 1 [username username] 56 Oct 24 15:51 Access-Your-PrivateData.desktop -> /usr/share/ecryptfs-utils/ecryptfs-mount-private.desktop
lrwxrwxrwx 1 [username username] 32 Oct 24 15:51 .Private -> /home/.ecryptfs/[username]/.Private
lrwxrwxrwx 1 [username username] 32 Oct 24 15:51 README.txt -> /usr/share/ecryptfs-utils/ecryptfs-mount-private.txt
