This is what my picture would look like if I was allowed to post pictures...
Account Type Administrator
Language English (New Zealand)
Login Options [blank]
Password ****
Last Login Logged in
My Account is the only account - the administrator account - and the blank space is there whether the dialog box is locked or unlocked, as is the complete absence of the Auto Login option at the bottom.
I have 14.04 installed. I have 3 drives, so researching through the other login questions suggests that my drive might be encrypted. If it is, I need simple to follow steps to fix this so Ubuntu will auto login.
All I want is for Ubuntu to auto login on startup. None of the other questions in the forums has been helpful.
This question seems to ask the same question as this: Ubuntu 14.10 Auto Login I'm wondering now if this is a serious flaw in 14 that can't be fixed, or changed. This seems to provide the answer for 12.04 - would it likely be the same for 14? How can I enable autologin for my user account when the option is not there?
Output for:
$ sudo lsblk -o NAME,TYPE,UUID,MOUNTPOINT:
NAME   TYPE UUID                                 MOUNTPOINT
sda    disk
└─sda1 part E8325C83325C58A0
sdb    disk
├─sdb1 part 7e9949df-0e95-45f1-919d-23b449f415fd /
├─sdb2 part
├─sdb3 part CA66EB5F66EB4AB1                     /mnt/CA66EB5F66EB4AB1
├─sdb4 part
└─sdb5 part 4868A0F868A0E5C2
$ cat /home/.ecryptfs/$USER/.ecryptfs/Private.mnt
/home/warwick
Warwick
Go to System Settings > User Accounts. Make sure to press Lock / Unlock in the upper right corner of the window. Then you can use the switch to enable Automatic-Login.
If you are using home folder encryption auto-login is not reasonable. But you can disable encryption if you follow the steps of the answer to the second linked question.
Michael
  • 126
