I did the update from Ubuntu 14.04 to Ubuntu 14.10 yesterday. Today I tried to run g++-4.8 as I normally do, but I have the following error:
make: g++-4.8: Command not found
I have the same error with g++-4.9 or g++. I tried installing g++ again:
sudo apt-get install g++
But I have the following error message:
 g++ : Depends: g++-4.9 (>= 4.6.4-1~) but it is not going to be installed
Then I tried dist-upgrade:
sudo apt-get dist-upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages have been kept back:
  libc6 libc6:i386 libc6-dbg valgrind
0 upgraded, 0 newly installed, 0 to remove and 4 not upgraded.
And install -f:
sudo apt-get install -f
but it did not change anything. I purged gcc and build-essential. But I have the same error when trying to reinstall build-essential:
sudo apt-get install build-essential
 build-essential : Depends: libc6-dev but it is not going to be installed or
                            libc-dev
                   Depends: g++ (>= 4:4.4.3) but it is not going to be installed
Edit: I looked at this answer but it failed removing the package libc6:
romain@romain-N56VZ:~$ sudo apt-get remove --dry-run libc6
 hunspell-fr : Depends: hunspell-fr-classical but it is not going to be installed or
                        hunspell-fr-modern but it is not going to be installed or
                        hunspell-fr-revised but it is not going to be installed or
                        hunspell-fr-comprehensive but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
Romain
  • 101
Ok I fixed it:
I removed the packages that were causing the errors, starting by valgrind:
sudo apt-get remove valgrind
and then the 3 other ones. And no more errors after that.
Romain
  • 101
