I changed my laptop from a Lenovo U310 to a Dell Inspiron 7537. The Lenovo had a special key for turning off and on the screen, but the Dell doesn't have it. I want to know if there is a command for turning off and on the screen by using the same keyboard shortcut (something like CTRL+A, or similar).
There are two circumstances that make your situation a bit different from the supposed duplicate(s):
- Some process seems to wake your screen up, if your screen wakes up after the
xset dpms force offcommand, it must be. My screen doesn't for example. - If you don't want your screen to wake up, just with any key press, the
xset dpms force offcommand is not doing what you want.
A workaround is the script below. What it does:
- It looks up your screen's name and the current brightness
- if the brightness is not equal to zero, it blacks the screen, else it sets brightness to normal
In other words: It toggles between black screen and normal brightness.
How to use
Copy the script into an empty file, save it as
toggle_screen.pyRun it by the command:
python3 /path/to/toggle_screen.pyMake sure you can repeat the command with a black screen, or else you will have to log out to toggle back...
If it works as you'd like it to, add it to a keyboard shortcut: Choose: System Settings > "Keyboard" > "Shortcuts" > "Custom Shortcuts". Click the "+" and add the command.
The script
#!/usr/bin/env python3
import subprocess
cmd1 = "xrandr --verbose"
get = subprocess.check_output(["/bin/bash", "-c", cmd1]).decode("utf-8").split()
brightness = get[get.index("Brightness:")+1]
screens = [get[i-1] for i in range(len(get)) if get[i] == "connected"]
if brightness == "1.0":
for scr in screens:
subprocess.Popen(["/bin/bash", "-c", "xrandr --output "+scr+" --brightness 0"])
else:
for scr in screens:
subprocess.Popen(["/bin/bash", "-c", "xrandr --output "+scr+" --brightness 1"])
- 85,475
