Edit: This is Ubuntu 13.04
Before I begin, I've seen this question around,
 sudo apt-get install openjdk-7-jdk
It tells me
... ect .. ect (Failed to fetch)
Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/o/openjdk-7/icedtea-7-jre-jamvm_7u25-2.3.10-1ubuntu0.13.04.2_amd64.deb  404  Not Found [IP: 91.189.91.23 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
so then I run
sudo apt-get --fix-missing install openjdk-7-jdk
and it tells me that it still cant fetch and unable to correct missing.
I also run sudo apt-get update to no affect.
Any ideas?
Installing java, Thanks!
k9b
  • 103
Ubuntu 13.04 has reached it End of Life(EOL) and its repositories have been moved to an archive server. Use this link to change your sources to the archive server.
However, I would advise you to install a supported version, ie Ubuntu 14.04 or 14.10.
