I have a Logitech Performance MX mouse I want to configure for Ubuntu 14.10 using xbindkeys. I managed to install xbindkeys and xautomation following this post, however, the buttons still don't work.
Here is my xbindkeysrc file:
# For the benefit of emacs users: -*- shell-script -*-
# xbindkeys configuration #
# Version: 1.8.6
# If you edit this file, do not forget to uncomment any lines
# that you change.
# The pound(#) symbol may be used anywhere for comments.
# To specify a key, you can use 'xbindkeys --key' or
# 'xbindkeys --multikey' and put one of the two lines in this file.
# The format of a command line is:
# "command to start"
# associated key
# A list of keys is in /usr/include/X11/keysym.h and in
# /usr/include/X11/keysymdef.h
# The XK_ is not needed.
# List of modifier:
# Release, Control, Shift, Mod1 (Alt), Mod2 (NumLock),
# Mod3 (CapsLock), Mod4, Mod5 (Scroll).
# The release modifier is not a standard X modifier, but you can
# use it if you want to catch release events instead of press events
# By defaults, xbindkeys does not pay attention with the modifiers
# NumLock, CapsLock and ScrollLock.
# Uncomment the lines above if you want to pay attention to them.
#keystate_numlock = enable
#keystate_capslock = enable
#keystate_scrolllock= enable
# Examples of commands:
"xbindkeys_show"
control+shift + q
# set directly keycode (here control + f with my keyboard)
#"xterm"
# c:41 + m:0x4
# specify a mouse button
#"xterm"
# control + b:2
#"xterm -geom 50x20+20+20"
# Shift+Mod2+alt + s
## set directly keycode (here control+alt+mod2 + f with my keyboard)
#"xterm"
# alt + c:0x29 + m:4 + mod2
## Control+Shift+a release event starts rxvt
#"rxvt"
# release+control+shift + a
## Control + mouse button 2 release event starts rxvt
#"rxvt"
# Control + b:2 + Release
"xte 'key Control_L'"
b:10
# End of xbindkeys configuration #
Thanks.
