I turned off my PC (Ubuntu 14.04) and when I turned it back on the fonts had changed (file names, folder names etc.). Why did this happen and how can I change the fonts again?
Now is this way:
Maybe it's the font/UI scaling. There is a bug declared in https://bugs.launchpad.net/ubuntu/+source/unity/+bug/1317253
To change the default font there is a similar question Change default system font using terminal only in 14.04
Using "Unity Tweak Tool" you can customize your default font and themes,
Command to install this:
sudo apt-get install unity-tweak-tool gnome-tweak-tool
You may be asked your system password, for installation.
To open Unity Tweak Tool, open the Dash and search for Unity, open the Unity - > Appearance section and select your customized themes and fonts. Check they work after a restart.
It's too late, but I think this answer can help someone
Just execute this code and restart your computer
sudo apt-get dist-upgrade
