13
The following question answers how to Adjust fonts using tweak tool but the luddite in me would like to know how to do this without installing unity-tweak-tool.
How can I adjust the default system font from a terminal.
Tahnoon Pasha
  • 446
  • 16
gsettings offers a simple commandline interface to GSettings. It lets you get, set or monitor an individual key for changes.
  • You can set fonts by following commands in terminal :
    gsettings set org.gnome.desktop.interface document-font-name 'Sans 10'
    gsettings set org.gnome.desktop.interface font-name 'Ubuntu 10'
    gsettings set org.gnome.desktop.interface monospace-font-name 'Ubuntu Mono 11'
    gsettings set org.gnome.nautilus.desktop font 'Ubuntu 10'
  • To Know current settings type following commands in terminal :
    gsettings get org.gnome.desktop.interface document-font-name
    gsettings get org.gnome.desktop.interface font-name
    gsettings get org.gnome.desktop.interface monospace-font-name
    gsettings get org.gnome.nautilus.desktop font
Additional:
  • To find all similar keys on schema type following command:
    gsettings list-recursively org.gnome.desktop.interface
  • To reset all valuses of keys run following command in terminal:
    gsettings reset-recursively org.gnome.desktop.interface
Pandya
  • 37,289
Recent updates have been changing the font scaling factors on my system, reset them with this command...
gsettings set org.gnome.desktop.interface text-scaling-factor '1.0'
AndyGF
  • 91
You can use dconf to change the default system font:
dconf write /org/gnome/desktop/interface/font-name "'NanumGothic Italic 11'"
To restore the original value:
dconf write /org/gnome/desktop/interface/font-name "'Ubuntu 11'"
Note: to check the current value, use the following command:
dconf read /org/gnome/desktop/interface/font-name
you could also try this answer:
setfont /usr/share/consolefonts/UbuntuMono-R-8x16.psf
this is an example; you can see a list of available fonts like this:
ls /usr/share/consolefonts
and should you for some reason not have them, you can install them like this:
sudo apt-get install fonts-ubuntu-font-family-console
note that you may need to put the setfont command in your .profile or .bashrc as it may need to be run upon every login
jmarina
  • 1,075
