test.png PNG 1920x1080 1920x1080+0+0 8-bit DirectClass 275KB 0.000u 0:00.000
$ xwininfo -root | grep Depth
  Depth: 24
It generates 8-bit images, but I want 24-bit depth screenshots.
I need to generate high quality screenshots, any idea?
I did look into --help and --help-all and --help-gtk parameters of gnome-screenshot
Zanna
  • 72,312
I got this hint from Bash script to take screenshot and save the image - Ubuntu. I alternatively used imagemagick and vary the depth using the following (hint from here on imagemagick.org).
-depth value
depth of the image.
This the number of bits in a color sample within a pixel. Use this option to specify the depth of raw images whose depth is unknown such as GRAY, RGB, or CMYK, or to change the depth of any image after it has been read.
f01
  • 246
imagemagick import subjectively brings much better image quality even without quality arguments (or -define png: arguments)
but it indeed shows 8-bit depth:
  test.png PNG 1920x1080 1920x1080+0+0 8-bit DirectClass 359KB 0.000u 0:00.000
But the picture is of much better quality than with gnome-screenshot
I have to figure out how best to define the png parameters for import (I want lossless compression) but I think it might be for another question.
import might be buggy. Another possibility might be shutter, but it has far fewer command line arguments
Zanna
  • 72,312
