33
I have Ubuntu Server 11.04, but it is headless (no monitor). The only way I want to be able to access it is remotely via SSH. But, sometimes, say after a power loss, when the server restarts, it will get stuck on the Grub boot menu, and it won't count down. It will just hang there waiting for me to choose the first boot entry. This means I have to go there and plug in a monitor and keyboard.
But I can't do that remotely. How can I force it to continue booting to boot entry 1 (default) regardless of power loss or whatever?
nLinked
  • 3,387
As of Ubuntu 12.04, a more straightforward, but nevertheless undocumented, solution is to use /etc/default/grub to override the recordfail timeout:
GRUB_TIMEOUT=10
GRUB_RECORDFAIL_TIMEOUT=$GRUB_TIMEOUT
Then run sudo update-grub to apply the changes.
The fact that such option is completely undocumented is just too bad.
Actually, the support for GRUB_RECORDFAIL_TIMEOUT was added in the middle of the 12.04 cycle, starting from version 1.99-21ubuntu3.3:
  grub2 (1.99-21ubuntu3.3) precise-proposed; urgency=low
[ Ben Howard ]
* Parameterization of recordfail setting. This allows users to define the
  default time out of GRUB when recordfail has been set. The curren
  setting causes hangs on headless and appliances where access to the
  console is limited or prohibited.  (LP: #669481)  [1]
-- Louis Bouchard <louis.bouchard@canonical.com>  Tue, 21 Aug 2012 10:51:58 +0200
More detailed information from LaunchPad.
Carolus
  • 600
C2H5OH
  • 909
10
The answer to this one can be found in the grub file /etc/grub.d/00_header
make_timeout ()
    cat << EOF
if [ "\${recordfail}" = 1 ]; then
  set timeout=-1
else
  set timeout=${2}
fi
EOF
Setting the timeout value to -1 will stop the count down. Change the value to a value > 0 i.e. set timeout=10
this section of the file would look like
make_timeout ()
    cat << EOF
  set timeout=10
else
  set timeout=${2}
fi
EOF
Then run
sudo update-grub2
fossfreedom
  • 174,526
