I am trying to install svn and am running into issues. The command I am running is sudo apt-get install svn. When I run this, I get the error "Unable to locate package svn". Why is this? How do I fix it?
Asked
Active
Viewed 4.2e+01k times
162
girardengo
- 5,005
coffee
- 1,621
250
The package is called subversion (abbreviated svn). You've to install it by running:
sudo apt-get install subversion
This package contains the svnserve daemon too (not started by default). If you want to host a subversion server over HTTP, you must install apache2 and configure it accordingly.
matan h
- 117
Lekensteyn
- 178,446
21
There is no package with the name of SVN . You may type this command on terminal.
Then you can check it using svn command
svn co "type here your checkout URL without double quotes"
svn status
svn commit ...........your file name
muru
- 207,228
Ashish Saini
- 541
apt-get is an amazing package manager, but often the names of packages aren't exactly named the way you would expect. (Obviously not the fault of apt-get) for example, downloading java isn't apt-get install java.
as for your issue, the name of the svn package in apt-get is subversion.
have fun with your subversion needs!
