I updated my system to the latest ubuntu from 14.04 to 14.10. It looks like it removed my tellico that was installed and removed the dependancies :-( Grrrr!
I tried an apt-get to install Tellico and got the following missing dependancies. Can anyone assist me with resolving this?
I'm thinking the upgrade removed the shared KDE dependancies/libraries?
Someone@MSTUltra:~$ sudo apt-get install tellico
Reading package lists... Done
Building dependency tree
The following information may help resolve the situation:
tellico : Depends: tellico-data (= 2.3.8+dfsg.2-1ubuntu1) but 2.3.9-0ubuntu0~ppa2 is to be installed
The same issue occurs when installing through the software center, please see below
 tellico: Depends: tellico-data (= 2.3.8+dfsg.2-1ubuntu1) but 2.3.9-0ubuntu0~ppa2 is to be installed
 Depends: libc6 (>= 2.4) but 2.19-10ubuntu2 is to be installed
 Depends: libgcc1 (>= 1:4.1.1) but 1:4.9.1-16ubuntu6 is to be installed
 Depends: libkabc4 (>= 4:4.7) but 4:4.14.1-0ubuntu1 is to be installed
 Depends: libkcal4 (>= 4:4.7) but 4:4.14.1-0ubuntu1 is to be installed
 Depends: libkcddb4 (>= 4:4.3.4) but 4:4.14.1-0ubuntu1 is to be installed
 Depends: libkdecore5 (>= 4:4.7) but 4:4.14.1-0ubuntu1 is to be installed
 Depends: libkdeui5 (>= 4:4.7.0) but 4:4.14.1-0ubuntu1 is to be installed
 Depends: libkhtml5 (>= 4:4.7) but 4:4.14.1-0ubuntu1 is to be installed
 Depends: libkio5 (>= 4:4.7.0) but 4:4.14.1-0ubuntu1 is to be installed
 Depends: libknewstuff3-4 (>= 4:4.7) but 4:4.14.1-0ubuntu1 is to be installed
 Depends: libkparts4 (>= 4:4.7) but 4:4.14.1-0ubuntu1 is to be installed
 Depends: libkresources4 (>= 4:4.7) but 4:4.14.1-0ubuntu1 is to be installed
 Depends: libksane0 (>= 4:4.3.4) but 4:4.14.1-0ubuntu1 is to be installed
 Depends: libkxmlrpcclient4 (>= 4:4.7) but 4:4.14.1-0ubuntu1 is to be installed
 Depends: libqimageblitz4 (>= 1:0.0.4) but 1:0.0.6-4build1 is to be installed
 Depends: libqt4-dbus (>= 4:4.5.3) but 4:4.8.6+git49-gbc62005+dfsg-1ubuntu1 is to be installed
 Depends: libqt4-network (>= 4:4.5.3) but 4:4.8.6+git49-gbc62005+dfsg-1ubuntu1 is to be installed
 Depends: libqt4-xml (>= 4:4.5.3) but 4:4.8.6+git49-gbc62005+dfsg-1ubuntu1 is to be installed
 Depends: libqtcore4 (>= 4:4.8.0) but 4:4.8.6+git49-gbc62005+dfsg-1ubuntu1 is to be installed
 Depends: libqtgui4 (>= 4:4.8.0) but 4:4.8.6+git49-gbc62005+dfsg-1ubuntu1 is to be installed
 Depends: libsolid4 (>= 4:4.7) but 4:4.14.1-0ubuntu1 is to be installed
 Depends: libstdc++6 (>= 4.9) but 4.9.1-16ubuntu6 is to be installed
 Depends: libxml2 (>= 2.7.4) but 2.9.1+dfsg1-4ubuntu1 is to be installed
 Depends: libyaz4 (>= 4.0.1) but 4.2.30-4 is to be installed
Rinzwind
  • 309,379
jr223
  • 131
To resolve unmet dependecies run the following command from your terminal
sudo apt-get -f install
If the problem still persists , go through the solution mentioned here
yask
  • 672
