I recently switched to Ubuntu and after I installed my NVidia driver package by using sudo apt-get install nvidia-current I relaunched my pc and everything seemed fine in the login screen but after I logged in the only thing I could was moving my mouse around on my background
I tried following the Unity doesn't load, no Launcher, no Dash appears thread and I got to the ccsm menu and checked the Ubuntu unity plugin as described but my icons would not appear so I rebooted but I ended up with the same problem
I would appreciate if someone could find a solution to my problem.
You should press Ctrl+Alt+F1 which brings you to a black terminal screen. Log in there with your normal user name and password.
Then you should follow this procedure: How can I uninstall a nvidia driver completely ?
Fabby
  • 35,017
