I have fixed this problem by enabling IOMMU in BIOS. This seems to be a motherboard specific issue.
Forum thread: http://ubuntuforums.org/showthread.php?t=2111223&p=12503485#post12503485
Just wanted to add to this thread in case in helps someone -- I have
also been experiencing this bug (Networking and USB not working with
64-bit Linux kernels on the Gigabyte 970A-D3 Rev. 3.0 motherboard). I
originally posted about it in this thread if you want gory details.
Note that my motherboard is a D3, not a DS3, though they are almost
identical.
Also note my motherboard is Rev. 3.0. The Revision is important as it
has a different bios than the earlier Revs; also, I did not have this
problem with the earlier Rev that I used briefly.
Further note, 32-bit kernels work fine, it's only the 64-bit ones that
don't have successfull Networking and USB.
And further note - the same problem exists in the current 13.04 Raging
64-bit kernel as well.
The good news: I was able to get my system working by setting IOMMU to
ENABLED in the bios (it was set to disabled by 'optimized
settings'/defaults).
YMMV. I figured out that I should play with this setting by going
through this thread and the similar launchpad bug mentioned earlier (
), though I don't know if anyone else solved it by the same method.
Not 100% sure where this bug should be reported to. Its not strictly a
Ubuntu bug, it affects all 64-bit kernels (that I tried, at least). I
guess it might be considered primarily a gigabyte bug. Not sure. I do
feel, though, that it would be better if the kernel gave some more
useful warning / debug messages in this case so people could diagnose
it better. I ended up spending many hours working on this.
