17
I need to synchronise my iPod Nano (5th generation) with music and podcasts (video and audio). I can use Rhythmbox for music, but does not seem to work with Podcast.
So, what application can I use to synchronize my podcats ?
Edit : After a week of fight with my iPod Nano, i've definitively uninstalled Banshee and i finally use Rhythmbox. Why ? because several times my music and podcast list in my iPod have been corrupted (3 times the same podcast, podcast in music and music in podcast, wrong covers ...)
I start this new week testing RhythmBox....
Edit 2 : finally found a solution with gPodder, read my answer for details
teo96
  • 1,169
9 Answers9
13
Banshee is the best I know.
nicoulaj
  • 268
10
Banshee 1.8 is undoubtedly the best one. You can simply install Banshee from Software-Center, then add the Banshee-Team repository (trough Software Center > Edit > Software Sources > Other Software > Add, and then fill in with ppa:banshee-team/ppa), and update your system trough the Update Manager.
Banshee will be in Applications > Sound and Video > Banshee Media Player. You can now plug-in your iPod, activate Banshee Podcast Plugin trough Edit > Preferences > Extensions, add your podcast and configure syncing in the iPhone's pane in Banshee.
After many tests, i found a solution to my problem :
  • Rhythmbox or Banshee for music
  • gPodder for podcasts
This configuration works fine with iPod Nano 5th generation
Details :
  • Banshee corrupts iPod library if you synchronize podcasts (3 times the same podcast, podcast in music and music in podcast, wrong covers ...)
  • Rhythmbox synchronize every podcasts but convert video podcasts into audio podcasts (very long synchronization process with high CPU usage)
  • gPodder version 2.9 works fine with audio and video podcasts (add gPodder ppa for the 2.9 version : deb http://ppa.launchpad.net/thp/gpodder/ubuntu maverick main )
teo96
  • 1,169
I would give Amarok a look, I have used it in the past good support as well.
myusuf3
  • 35,659
Use Banshee or Rythmbox is indiferent, the two have a good integration with iPod.
Rhythmbox supports podcasts and doesn't require additional plugins to do so. I use it myself and can confirm that it works.
Go to "Edit > Preferences > Podcasts" to set up the folder where your podcasts will be downloaded and how often to check for new episodes.
What version of Rhythmbox do you have and which version of Ubuntu? I run Lucid with rhythmbox 0.13.1
Antonis
  • 710
I usually use gtkpod for this.
gtkpod is a graphical user interface for the Apple iPod for Unix-like systems, written using the GTK+ toolkit.
gtkpod allows you to:
* Read your existing iTunesDB (i.e. import the existing contents of your iPod including playcounts, ratings and on-the-go playlists).
* Add MP3, WAV, M4A (non-protected AAC), M4B (audio book), podcasts, and various video files (single files, directories or existing playlists) to the iPod.
landroni
  • 6,011
have a look at Floola I use if for my ipod video classic it downloads podcasts and I can add music/audiobooks in mp3 format or apples formats. It also support album art.
My favorite is Exaile It's goal is to be like Amarok, built for GTK.
landroni
  • 6,011
TheXed
  • 27,638
