My Ubuntu version is new, and Intel Graphics Installer doesn't allow me to install the Intel video drivers. It says "Distribution not supported"
How can I resolve this problem?
Asked
Active
Viewed 2.5k times
18
That software checks /etc/lsb-release and that is a text file we can edit ourself so it might be fairly easy to circumvent. Make a backup first though if you do not know what this means. From a command line:
sudo cp /etc/lsb-release /etc/lsb-release.backup
And then edit the file ...
sudo gedit /etc/lsb-release
And change the lines as below:
DISTRIB_RELEASE=14.10
DISTRIB_CODENAME=utopic
And save it. Start the installation and it should finish this time without a notice regarding the distribution.
After that you can then put back the backup file with (cp to leave the backup, change it to mv to also remove the backup)...
sudo cp /etc/lsb-release.backup /etc/lsb-release
