I am trying to emulate left-mouse-down when Home key is down and left-mouse-up when Home key is released.
The reason behind that is my touchpad's buttons are terrible and I like to use the track-point (red nipple) with left mouse click for highlight (copy) text. Instead of using the touchpad's button I want to use the 'Home' key. I am able to emulate the mouse-down part but I don't know how to release the click when the 'Home' key is released.
Here is what I have so for. first I use the xbindkeys tool. I added this entry to the .xbindkeysrc:
"~/bin/mouse-click"
  m:0x0 + c:110
mouse-click is this bash script:
#!/bin/bash
xdotool mousedown 1
The problem is the click is never being released so I need to find a way to detect the release of the 'Home'. Here is the script I am trying to write. The comments describe what I am trying to do:
#!/bin/bash
# not sure how to do that:
exit if Home key is in a pressed state (to avoid more mousedown actions)
xdotool mousedown 1
# not sure how to do that: (if Home key is released, release the mouse click)
while xinput query-state <device name> | grep -Flq 'key[9]=up'
xdotool mouseup 1
So That's what I am trying to figure out:
  1. Query the state of 'Home' key (pressed or not).
  2. Listen to keyboard events and detect a release of 'Home' key.
If there are better approach to achieve that, I would love to hear about them. Thanks!
Edit: the solution is one line: xmodmap -e "keycode 115 = Pointer_Button2"
so now my Home key is doing left click and behave just as if I hit the mouse click and I can keep the key pressed and it highlights (copy) as expected.
I also mapped my End key to be middle click, so I can use it to paste: xmodmap -e "keycode 110 = Pointer_Button1"
The solution is
Now my Home key is doing left click and behaves just as if I hit the mouse click and I can keep the key pressed and it highlights (copies) as expected.
Note that it is necessary to have "mousekeys" (mouse emulation using the numeric keypad) enabled for this to work. "mousekeys" can be toggled by pressing Shift+NumLock or set explicitly by running:
dconf write /org/gnome/desktop/a11y/keyboard/mousekeys-enable true
dconf write /org/gnome/desktop/a11y/keyboard/mousekeys-enable false
Most desktops have some accessibility settings that will control the mouse with the keyboard already built-in, like XFCE has them in it's All Settings -> Accessibility -> Mouse -> Mouse Emulation, that uses the keyboard number pad so the 5 key does exactly what you're trying to do.
If I recall, gnome, cinnamon and mate have similar features under something like "Accessibility" or assistive technology, etc. Or an installable program/package like mousetweaks ("mouse accessibility enhancements for the GNOME desktop") or keynav (but I couldn't get it to work on xfce).
Or, if your touchpad still works ok (just not the buttons) you could just do a tap for a single click, a tap & then hold for a click & drag, a double-tap = double click... and if they don't work there should be a line or two in the terminal that should get those to work (don't remember them offhand now). I wouldn't want to write my own script when there are a few other options that should work
Xen2050
  • 8,943
You should use for that an auto clicker program that emulate and automate your mouse clicks (left mouse button in your case).
I recommend for you to use Max Auto Clicker that is available for Ubuntu Linux and other debian like distros.
Available packages format: .deb, .AppImage, .zip
Alexif_47
  • 557
