I have this very silly and very basic question but I thought better to ask before I start pruning my NAS.
I want to delete all directories in which all files are older than 30 days.
For files I could have done:
find /path/to/files* -mtime +30 -exec rm {} \;
But this would lead to empty folders at some places. So I was thinking to rather delete all folders with -mtime +30 but I am not sure if the mtime of folder guarantees mtime threshold for it sub folders and files.
Also, if what I am think is right, what would be the command for the same?
On linux directory modification time change if you:
  • add a new file
  • remove an existent a file
  • or rename a file in it
If you change content of existent file, this is not reflected up to directory.
Because of this, I suggest to use these commands:
    find /path/to/folder -type f -mtime +30 -delete
this command remove recursively file older than 30 days and preserve folder.
    find /path/to/folder -type d -empty -delete
this remove empty directory if any.
Source:
Directory last modified date
How do I delete all empty directories in a directory from the command line?
Lety
  • 6,089
  • 32
  • 38
