I wanted to install VLC on Ubuntu, it wasn't working, updated system, than upgraded it, but still it isn't working.
I used both the Ubuntu Software center and the Terminal for that.
In the terminal I typed the command sudo apt-get install vlc
The error message terminal gives me is as follows.
arif@arifpc:~$ sudo apt-get install vlc
[sudo] password for arif:
Reading package lists... Done
Building dependency tree
 vlc : Depends: vlc-nox (= 2.2.0~rc1-1ppa2~trusty) but it is not going to be installed
       Depends: libavcodec56 (>= 7:2.4~) but it is not going to be installed
       Depends: libgles1-mesa (>= 7.8.1) but it is not installable or
                libgles1 but it is not installable
       Depends: libsdl-image1.2 (>= 1.2.10) but it is not installable
       Depends: libsdl1.2debian (>= 1.2.11) but it is not installable
       Depends: libva-drm1 but it is not installable
       Depends: libva-x11-1 (> 1.3.0~) but it is not installable
       Depends: libva1 (> 1.3.0~) but it is not installable
       Depends: libvlccore8 (>= 2.2.0~pre1) but it is not going to be installed
       Depends: libxcb-composite0 but it is not installable
       Depends: libxcb-xv0 (>= 1.2) but it is not installable
       Recommends: vlc-plugin-notify (= 2.2.0~rc1-1ppa2~trusty) but it is not going to be installed
       Recommends: vlc-plugin-samba (= 2.2.0~rc1-1ppa2~trusty) but it is not going to be installed
Note:I'm using Ubuntu 14.04 LTS
Bangash
  • 221
This happened to me after the upgrade from Ubuntu 14.04 to 14.10.
I found this Solution that helped me.
You need to add the xorg-edgers fresh X crack Repository with this Code in Terminal:
sudo add-apt-repository ppa:xorg-edgers/ppa
apt-cache policy libgl1-mesa-glx libglapi-mesa
Then Reboot your PC. Then update the repositories with the following commands and install VLC:
sudo apt-get update
David Foerster
  • 36,890
  • 56
  • 97
  • 151
Aby
  • 883
By using aptitude i can solve this issue.
source
my topic in UBUNTU.ir community
Solution
sudo apt install aptitude
sudo aptitude install vlc
now you must choose: n
Then terminal will output
Downgrade the following packages:
1)     libgl1-mesa-glx [12.0.6-0ubuntu0.16.04.1 (now) -> 11.2.0-1ubuntu2 (xenial
2)     libglapi-mesa [12.0.6-0ubuntu0.16.04.1 (now) -> 11.2.0-1ubuntu2 (xenial)]
Accept this solution? [Y/n/q/?] y
Now aptitude downgrades depending packages and install vlc.
EsmaeelE
  • 425
  • 16
Run the following commands
sudo apt-get -f install
sudo dpkg --configure -a
This should install all missing dependencies and configure dpkg.
Actually I solved this problem the same day, the problem was with the nearest archive.ubuntu.com (Ubuntu Archive Server) I changed all of its instances (13 occurrences in my case) to us.archive.ubuntu.com and it worked. The configuration file where I changed this setting was /etc/apt/sources.list.
Edit: Recently I found another question on askubuntu, the accepted answer to this question is also a nice solution to this problem if you don't want to change the archive.ubuntu address.
Here is that question.
Bangash
  • 221
