Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
vlc : Depends: vlc-nox (= 2.2.2+git20160830+r58831+56~ubuntu16.04.1) but it is not going to be installed
Depends: libavcodec-ffmpeg56 (>= 7:2.4) but it is not going to be installed or
libavcodec-ffmpeg-extra56 (>= 7:2.4) but it is not going to be installed
Depends: libavutil-ffmpeg54 (>= 7:2.4) but it is not going to be installed
Depends: libgles1-mesa (>= 7.8.1) but it is not going to be installed or
libgles1
Depends: libgles2-mesa (>= 7.8.1) but it is not going to be installed or
libgles2
Depends: libqt5x11extras5 (>= 5.1.0) but it is not going to be installed
Depends: libsdl-image1.2 (>= 1.2.10) but it is not going to be installed
Depends: libsdl1.2debian (>= 1.2.11) but it is not going to be installed
Depends: libva-drm1 (>= 1.1.0) but it is not going to be installed
Depends: libva-x11-1 (>= 1.0.3) but it is not going to be installed
Depends: libva1 (>= 1.2.0) but it is not going to be installed
Depends: libvlccore8 (>= 2.2.0) but it is not going to be installed
Depends: libxcb-composite0 but it is not going to be installed
Depends: libxcb-xv0 (>= 1.2) but it is not going to be installed
Recommends: vlc-plugin-notify (= 2.2.2+git20160830+r58831+56~ubuntu16.04.1) but it is not going to be installed
Recommends: vlc-plugin-samba (= 2.2.2+git20160830+r58831+56~ubuntu16.04.1) but it is not going to be installed
Conflicts: vlc:i386 but 2.1.4-1 is to be installed
vlc:i386 : Depends: vlc-nox:i386 (= 2.1.4-1) but it is not going to be installed
Depends: libaa1:i386 (>= 1.4p5) but it is not going to be installed
Depends: libc6:i386 (>= 2.15) but it is not going to be installed
Depends: libcaca0:i386 (>= 0.99.beta17-1) but it is not going to be installed
Depends: libfreetype6:i386 (>= 2.2.1) but it is not going to be installed
Depends: libfribidi0:i386 (>= 0.19.2) but it is not going to be installed
Depends: libgcc1:i386 (>= 1:4.1.1) but it is not going to be installed
Depends: libgl1-mesa-glx:i386 but it is not going to be installed or
libgl1:i386
Depends: libqtcore4:i386 (>= 4:4.8.0) but it is not going to be installed
Depends: libqtgui4:i386 (>= 4:4.8.0) but it is not going to be installed
Depends: libsdl-image1.2:i386 (>= 1.2.10) but it is not going to be installed
Depends: libsdl1.2debian:i386 (>= 1.2.11) but it is not going to be installed
Depends: libstdc++6:i386 (>= 4.6) but it is not going to be installed
Depends: libtar0:i386 but it is not going to be installed
Depends: libva-x11-1:i386 (> 1.3.0~) but it is not going to be installed
Depends: libva1:i386 (> 1.3.0~) but it is not going to be installed
Depends: libvlccore7:i386 (>= 2.1.0) but it is not installable
Depends: libx11-6:i386 but it is not going to be installed
Depends: libxcb-composite0:i386 but it is not going to be installed
Depends: libxcb-keysyms1:i386 (>= 0.3.9) but it is not going to be installed
Depends: libxcb-randr0:i386 (>= 1.1) but it is not going to be installed
Depends: libxcb-shm0:i386 but it is not going to be installed
Depends: libxcb-xv0:i386 (>= 1.2) but it is not going to be installed
Depends: libxcb1:i386 (>= 1.6) but it is not going to be installed
Depends: libxext6:i386 but it is not going to be installed
Depends: libxinerama1:i386 but it is not going to be installed
Depends: libxpm4:i386 but it is not going to be installed
Depends: zlib1g:i386 (>= 1:1.2.3.3) but it is not going to be installed
Recommends: vlc-plugin-notify:i386 (= 2.1.4-1) but it is not going to be installed
Recommends: vlc-plugin-pulse:i386 (= 2.1.4-1) but it is not installable
Conflicts: vlc but 2.2.2+git20160830+r58831+56~ubuntu16.04.1 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
I have tried eveything -f -f install
But nothing seems to work.
this is not all when ever i try sudo apt upgrade
I get the following error
You might want to run 'apt-get -f install' to correct these.
vlc:i386 : Depends: vlc-nox:i386 (= 2.1.4-1) but it is not installed
Depends: libaa1:i386 (>= 1.4p5) but it is not installed
Depends: libc6:i386 (>= 2.15) but it is not installed
Depends: libcaca0:i386 (>= 0.99.beta17-1) but it is not installed
Depends: libfreetype6:i386 (>= 2.2.1) but it is not installed
Depends: libfribidi0:i386 (>= 0.19.2) but it is not installed
Depends: libgcc1:i386 (>= 1:4.1.1) but it is not installed
Depends: libgl1-mesa-glx:i386 but it is not installed or
libgl1:i386
Depends: libqtcore4:i386 (>= 4:4.8.0) but it is not installed
Depends: libqtgui4:i386 (>= 4:4.8.0) but it is not installed
Depends: libsdl-image1.2:i386 (>= 1.2.10) but it is not installed
Depends: libsdl1.2debian:i386 (>= 1.2.11) but it is not installed
Depends: libstdc++6:i386 (>= 4.6) but it is not installed
Depends: libtar0:i386 but it is not installed
Depends: libva-x11-1:i386 (> 1.3.0~) but it is not installed
Depends: libva1:i386 (> 1.3.0~) but it is not installed
Depends: libx11-6:i386 but it is not installed
Depends: libxcb-composite0:i386 but it is not installed
Depends: libxcb-keysyms1:i386 (>= 0.3.9) but it is not installed
Depends: libxcb-randr0:i386 (>= 1.1) but it is not installed
Depends: libxcb-shm0:i386 but it is not installed
Depends: libxcb-xv0:i386 (>= 1.2) but it is not installed
Depends: libxcb1:i386 (>= 1.6) but it is not installed
Depends: libxext6:i386 but it is not installed
Depends: libxinerama1:i386 but it is not installed
Depends: libxpm4:i386 but it is not installed
Depends: zlib1g:i386 (>= 1:1.2.3.3) but it is not installed
Recommends: vlc-plugin-notify:i386 (= 2.1.4-1) but it is not installed
E: Unmet dependencies. Try using -f.
I have tried even the -f but nothing happens still.
Please Help
