I ran this command sudo chown -hR root /.
and now flash is disabled, chrome does not work, nothing works, I cannot even access folder directories outside of the terminal. I then logged out and tried to log back in and my password for the log on screen did not even work!
These were the posts I attempted to read and follow Change folder permissions and ownership
I have once before booted to the terminal, I forget the keypress function right now, but I believe this is the route I must take?
When I was logged on I received this error as I tried to follow the following posts' guidelines to somehow remedy what I previously did https://stackoverflow.com/questions/3740152/how-to-set-chmod-for-a-folder-and-all-of-its-subfolders-and-files-in-linux-ubunt
To change all the directories to 755 (-rwxr-xr-x):
find /opt/lampp/htdocs -type d -exec chmod 755 {} \;
To change all the files to 644 (-rw-r--r--):
find /opt/lampp/htdocs -type f -exec chmod 644 {} \;
but nothing worked from these commands except for this error message:
sudo: /usr/bin/sudo must be owned by uid 0 and hav the setuid bit set
I originally messed around with my permissions as I was annoyed with using sudo here and there and not having my commands fully work. I merely wanted to pip install twilio and pip install flask but previously when I ran these commands (with or without sudo) I received an error message telling my python3.4/dist-packages/ was unable to write the installation (I am using Python 2.7 - perhaps this is a problem?)
