I encountered a SIGBUS error when starting up eclipse. There was nothing wrong before this, I've just turned on the laptop and the error appears:
$ eclipse
# A fatal error has been detected by the Java Runtime Environment:
# SIGBUS (0x7) at pc=0x00007f08bd89063a, pid=4159, tid=139674439165696
# JRE version: OpenJDK Runtime Environment (7.0_65-b32) (build 1.7.0_65-b32)
# Java VM: OpenJDK 64-Bit Server VM (24.65-b04 mixed mode linux-amd64 compressed oops)
# Derivative: IcedTea 2.5.3
# Distribution: Ubuntu 14.04 LTS, package 7u71-2.5.3-0ubuntu0.14.04.1
# Problematic frame:
# C [libzip.so+0x463a]
# Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
# An error report file with more information is saved as:
# /home/alvas/hs_err_pid4159.log
# If you would like to submit a bug report, please include
# instructions on how to reproduce the bug and visit:
# http://icedtea.classpath.org/bugzilla
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
Has anyone had the same problem before? How do I resolved the problem?
Is it an IceTea JRE problem? I have tried installing the latest JDK with this: How do I install Java? but it didn't work.
The SIGBUS error in hs_err_pid4159.log is http://pastebin.com/w8YqFJE3
I've also tried this and it didn't work:
alvas@ubi:~$ sudo update-alternatives --config java
There are 2 choices for the alternative java (providing /usr/bin/java).
Selection Path Priority Status
* 0 /usr/lib/jvm/java-7-oracle/jre/bin/java 1072 auto mode
1 /usr/lib/jvm/java-7-openjdk-amd64/jre/bin/java 1071 manual mode
2 /usr/lib/jvm/java-7-oracle/jre/bin/java 1072 manual mode
Press enter to keep the current choice[*], or type selection number: 2
