13
Hi I am new to Ubuntu and recently installed 14.04 LTS. I am having issues with mounting external hard drives for all users at start up. For example, after start up if I login as a user A, only user A can access the external media, and others can't access these external media. Could someone please help me fix this issue.
Outputs to following commands
sudo blkid
/dev/sda1: UUID="98715d8d-bf13-48f5-882e-36270c539c94" TYPE="ext4"
/dev/sda2: UUID="qOUDEc-qHDq-y9NL-OWCF-fO04-vnPI-8UNrtV" TYPE="LVM2_member"
/dev/sdb1: UUID="6ulNAl-1Hky-orpE-ntL2-Brgu-Qen1-BYqCIh" TYPE="LVM2_member"
/dev/mapper/VolGroup-lv_root: UUID="a7e84558-d5d3-43f3-8788-a483dde96fd8" TYPE="ext4"
/dev/mapper/VolGroup-lv_home: UUID="fb65cc75-ab1a-44a4-8f98-b1767d03f15a" TYPE="ext4"
/dev/mapper/VolGroup-lv_swap: UUID="69e3381b-a2b5-4866-81b6-bd368c9157d5" TYPE="swap"
/dev/sdc1: LABEL="ExtHDD04" UUID="0DFFA1CB15212E12" TYPE="ntfs"
/dev/sdd1: LABEL="ExtHDD03" UUID="485AA7713243CEFB" TYPE="ntfs"
/dev/sde1: UUID="485ef4bd-0093-42c5-a3e5-0090e68e93c1" TYPE="ext4"
/dev/sr1: LABEL="WD SmartWare" TYPE="udf"
/dev/sdg1: LABEL="ExtHDD01" UUID="00148BDE148BD4D6" TYPE="ntfs"
sudo fdisk -l
Disk /dev/sda: 250.0 GB, 250000000000 bytes
255 heads, 63 sectors/track, 30394 cylinders, total 488281250 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0xc648a420
   Device Boot      Start         End      Blocks   Id  System
/dev/sda1   *        2048     1026047      512000   83  Linux
/dev/sda2         1026048   488280063   243627008   8e  Linux LVM
Disk /dev/sdb: 2000.4 GB, 2000398934016 bytes
255 heads, 63 sectors/track, 243201 cylinders, total 3907029168 sectors
Disk identifier: 0x000617c8
/dev/sdb1            2048  3907028991  1953513472   8e  Linux LVM
Disk /dev/mapper/VolGroup-lv_root: 53.7 GB, 53687091200 bytes
255 heads, 63 sectors/track, 6527 cylinders, total 104857600 sectors
Disk identifier: 0x00000000
Disk /dev/mapper/VolGroup-lv_root doesn't contain a valid partition table
Disk /dev/mapper/VolGroup-lv_home: 2168.7 GB, 2168656494592 bytes
255 heads, 63 sectors/track, 263657 cylinders, total 4235657216 sectors
Disk /dev/mapper/VolGroup-lv_home doesn't contain a valid partition table
Disk /dev/mapper/VolGroup-lv_swap: 27.5 GB, 27481079808 bytes
255 heads, 63 sectors/track, 3341 cylinders, total 53673984 sectors
Disk /dev/mapper/VolGroup-lv_swap doesn't contain a valid partition table
WARNING: GPT (GUID Partition Table) detected on '/dev/sdc'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/sdc: 3000.6 GB, 3000558944256 bytes
255 heads, 63 sectors/track, 364797 cylinders, total 5860466688 sectors
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
/dev/sdc1               1  4294967295  2147483647+  ee  GPT
Partition 1 does not start on physical sector boundary.
WARNING: GPT (GUID Partition Table) detected on '/dev/sdd'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/sdd: 3000.6 GB, 3000558944256 bytes
/dev/sdd1               1  4294967295  2147483647+  ee  GPT
WARNING: GPT (GUID Partition Table) detected on '/dev/sde'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/sde: 3000.6 GB, 3000558944256 bytes
/dev/sde1               1  4294967295  2147483647+  ee  GPT
Disk /dev/sdg: 1999.7 GB, 1999696297984 bytes
228 heads, 56 sectors/track, 305894 cylinders, total 3905656832 sectors
Disk identifier: 0xe534f55f
/dev/sdg1            2048  3905656831  1952827392    7  HPFS/NTFS/exFAT
cat /etc/fstab
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
/dev/mapper/VolGroup-lv_root /               ext4    errors=remount-ro 0       1
/dev/mapper/VolGroup-lv_home /home           ext4    defaults        0       2
/dev/mapper/VolGroup-lv_swap none            swap    sw              0       0
Jacob Vlijm
  • 85,475
To mount a partition at startup for all users, we need an entry in the fstab file. What is happening presently is, the HDD is getting mounted for the user who logs in which gives access permissions to only that user. By adding an entry in the fstab, the partition will be mounted by root with access to all users. this r/w access can be controlled later on.
sudo blkid lists down all partitions available on your system. Note down the UUID of the NTFS partition that you want to mount at boot. In your case, it seems 00148BDE148BD4D6
now create a folder, for example sudo mkdir /media/ExtHDD01. This is the folder where your external HDD partition will be mounted at. This folder will be owned by root. To give other users permission to r/w into this folder we need to give the proper permissions. so chmod -R 777 /media/ExtHDD01 would be good enough. Now you need to edit your fstab file. to do so, type the following command.
sudo nano /etc/fstab
go to the bottom of the file and add the following line there.
UUID=00148BDE148BD4D6 /media/ExtHDD01/    ntfs-3g        auto,user,rw 0 0
Reboot system and you should be good to go. You can follow the same procedure for any number of HDDs.
muru
  • 207,228
astrob0t
  • 1,766
14
GUI method
  1. plug in the drive.
  2. Go to Disks in the desktop finder (or sudo gnome-disks on a terminal)
  3. Select the correct disk in the left column.
  4. Click the gear icon enter image description here
  5. Select edit mount options
  6. Turn off
  7. Check both mount at startup and show user interface
Thats it!
I recently was in the same situation and I figured out a solution.
I have 2 users, ADMIN and DESKTOP USER for which I wanted to mount same drive labeled STORAGE upon their respective logins, so:
In the file /etc/fstab I had to add following entry:
LABEL=STORAGE /media/$USER/STORAGE auto nosuid,nodev,nofail,x-gvfs-show 0 0
The notable thing is the use of the environment variable $USER.
This is for Ubuntu 16.04 where new drive is mounted under /media/<username>/<drive-label>
You may also use UUID instead of <drive-label>.
Eliah Kagan
  • 119,640
