I've several problem with my sound card as : No sound when the HDMI is plugged, External SubWofer and the laptop speaker didn't switch off when I plugged headphone. It's an ASUS N550LF with 14.04 Kubuntu distribution.
Several forum and skill exchnage site told That I've add my model at the end of this line in my /etc/modprobe.d/alsa-base.conf file
options snd-hda-intel model=
But I have no idea what to put in after " model".
For help, there is the ling of the alsa-info sript: Alsa-project : alsa-info Result
I fixed the Subwofer problem but that could occur some conflict External Subwofer doesn't work.
dubis
  • 197
-The problem with HDMI may be solved with pavucontrol (install it if needed), and choosing default device in "output tab" (clicking green button)
-The problem with subwoofer may be solved by changing model as you suggest: your hda codec is Realtek ALC668 , and from this page , searching ALC66x/67x/892, you can try ASUS as model.
laugeo
  • 2,880
  • 14
according to Alsa logs you the models is not the name of laptops. you should test for example model=asus-mode1
and I think
snd-hda-intel is not correct snd_hda_intel is correct
so use options snd_hda_intel model=asus-mode4
