I am running Ubuntu version 14.04, and I have an apache2 server set up to host some php files on localhost that are stored in /var/www/html.
When I try to execute the following code in one of my php script
<?php
$file = fopen("test.txt","w");
fwrite($file,"Hello World. Testing!");
fclose($file);
I do not find a file stored in my /var/www/html named test.txt, or anywhere on my computer after searching. The file name does not already exist, and I am using sudo nautilus because I do not have the necessary permissions to edit the php files inside the /var/www/html. Why are the files not appearing in my /var/www/html folder and how can I fix this so that the file is created?
I just tested your php file in my server and it works just fine.
You problem must be that the user www-data doesn't have write permissions to that folder.
If indeed that user doesn't have write permissions to that folder, then you will see error messages at the file /var/log/apache2/error.log
In order to look at the last errors, do
tail -n 15 /var/log/apache2/error.log
For example, if I, instead of "test.txt", put "/test.txt" (write to /, were only root can) I get this error inside the log file:
[:error] [pid 7505] [client 127.0.0.1:47066] PHP Warning:  fopen(/test.txt): failed to open stream: Permission denied in /var/www/html/a.php on line 2
The above clearly states that permission is denied.
You can fix this problem by giving write permission to that folder for user www-data.
give specific user permission to write to a folder using +w notation
hytromo
  • 4,891
