I know I can assign the permission to write to an owner/group/others like this:
chmod u+w myfolder
Can I specify the specific user here? Some like this:
chmod username u+w myfolder
chmod u+w myfolder
You could use setfacl:
setfacl -m u:username:rwx myfolder
This sets permissions for specific users, without changing the ownership of the directory.
Check out the man page for further details and examples.
Note:
setfacl is short for set File ACL (Access Control List)
If you want to apply it recursively to all the subdirectories: add the -R flag like this:
setfacl -R -m u:username:rwx myfolder
If you want to change the user owning this file or directory (folder), you will have to use the command chown. For instance, if you run
sudo chown username: myfolder
the user owning myfolder will be username. Then you can execute
sudo chmod u+w myfolder
to add the write permission to the username user.
But if you want to add this user to the group associated with "myfolder", you can run
sudo usermod -a -G groupname username
and then execute
sudo chmod g+w myfolder
to add the write permission to the group.
No this is not possible. You can either change the owner of the file with
[sudo] chown username: foldername
or you can add the user to the group that owns the file with
usermod -a -G {group-name} username
In Ubuntu recursively (folder and it's all sub folders) giving permission to a specific user:
sudo chown -R <username>: <folderName>
