My computer is locking up while I'm using the trackpad. It seems to occur most after I install graphics drivers on a fresh install of ubuntu. It has occured once on a fresh install of 14.10. It also occurs in 14.04 after I install graphic drivers. I can't use ubuntu like this, because it's causing all sorts of problems. Does anyone know a fix?
I'm running an asus republic of gamers g750jm with a gtx860m graphics card in it. I don't believe I'm the only one with this problem and I found a solution that I believe works but it disables my trackpad's two-finger scroll. The page is here: http://www.hackingnotcracking.com/?p=112 does anyone know how to avoid disabling the two finger scroll so I can test and see if this page's suggestion fixes my problem?
UPDATE: I did test that pages solutions they didn't work. I still can't use Ubuntu unless I choose to not install drivers for my gtx860m,... so now I just don't install graphic drivers now.
UPDATE: I am following the instructions laid out here: Ubuntu and ASUS G750JM, GTX860M / Nvidia problems and running into this problem. Any advice or input may help the cause.
Still looking for a solution, I even set a bounty and nothing. I'd open a bug ticket on it but I'm using edgers drivers. When I try to install the nvidia drivers from their website lightdm won't even boot.
Daniel
  • 372
I was experiencing the same problems on a laptop with GTX 860M, Ubuntu 14.04. I had the mouse cursor freeze (actually it must have been lightdm locking up) due to having the wrong graphics driver active. I had tried with the one from GeForce.com without any luck. Here is how I eventually made it work:
First, make sure drivers from GeForce.com are uninstalled (if you have them installed, run the installation file again with the --uninstall flag).
Then, update your sources, purge any packages with reference to nvidia and bumblebee. Install nvidia-prime and nvidia-340. Run nvidia-xconfig and reboot. Here are the commands:
sudo apt-get update
sudo apt-get purge bumblebee*
sudo apt-get purge nvidia*
sudo apt-get install nvidia-prime
sudo apt-get install nvidia-340
sudo nvidia-xconfig
sudo reboot
Note: if you have trouble using the graphical interface, press [Ctrl]+[Alt]+[F1] and log in on the first cli interface. If needed, enter sudo service lightdm stop to stop the graphical interface before running the above commands.
Alasjo
  • 143
Turn on trackpad while using keyboard in settings, I found this answer online and so far it has resolved the problem
Daniel
  • 372
