After removing the gnome shell the battery indicator stuck on the first value it shows when I log in i.e. if at start it was 100% it is still like that till the battery dies. Can you please help me to solve this issue?
Update: tried the following command with no effect
apt-get install indicator-power --reinstall
UPDATE2 :
# upower -d Device: /org/freedesktop/UPower/devices/line_power_AC native-path: AC power supply: yes updated: 30 أكت, 2014 EET 09:13:30 م (1949 seconds ago) has history: no has statistics: no line-power
warning-level: none
online: yes
icon-name: 'ac-adapter-symbolic'
Device: /org/freedesktop/UPower/devices/battery_BAT0 native-path: BAT0 vendor: SMP model: DELL MKD6223 serial: 2093 power supply: yes updated: 30 أكت, 2014 EET 09:45:30 م (29 seconds ago) has history: yes has statistics: yes battery
present: yes
rechargeable: yes
state: charging
warning-level: none
energy: 18.4704 Wh
energy-empty: 0 Wh
energy-full: 33.2667 Wh
energy-full-design: 62.16 Wh
energy-rate: 20.0355 W
voltage: 12.404 V
time to full: 44.3 minutes
percentage: 55%
capacity: 53.5179%
technology: lithium-ion
icon-name: 'battery-good-charging-symbolic' History (charge):
1414698330 55.000 charging
Device: /org/freedesktop/UPower/devices/DisplayDevice power supply: yes updated: 01 ينا, 1970 EET 02:00:00 ص (1414698359 seconds ago) has history: no has statistics: no battery
present: yes
state: charging
warning-level: none
energy: 18.4704 Wh
percentage: 55%
Daemon: daemon-version: 0.99.1 on-battery: no lid-is-closed: no lid-is-present: yes critical-action: PowerOff
