I use terminal a lot. I wrote a script and have it in ~/blah/script.sh now. How can I run the script from Unity (Dash?)?
A long time ago I would have used ALT-F2 and typed my command, but that doesn't do what I expect now.
Maybe modifying some $PATH var somewhere so dash can find it...? I don't want to change the dir the script is in because it's in a place where I serve various scripts for reasons.
Tips?
Simply create a .desktop file and save it in ~/.local/share/applications. In its most basic form:
[Desktop Entry]
Name=name_of_your_script_like_you_see_it_in_Dash
Exec=sh /path/to/script.sh
Icon=/path/to/some/icon
Type=Application
Copy it into an empty file, save it as script.desktop in ~/.local/share/applications. After log out /in, it will appear in Dash.
If the script is executable, you can replace Exec=sh /path/to/script.sh by simply: Exec=/path/to/script.sh, or if you don't have the language extension on the script: Exec=/path/to/script
Note
If the path to your script contains (folder-) names with spaces, you can simply escape it by putting the name between quotes. For example:
Exec=sh /path/with/'Folder with spaces'/to/script.sh
(spaces in the path to your icon can/should be left as they are)
Jacob Vlijm
  • 85,475
