I get in some trouble when I tried to update the system
W: Failed to fetch http://archive.getdeb.net/ubuntu/dists/trusty-getdeb/apps/binary-amd64/Packages  521  Origin Down [IP: 104.28.24.125 80]
W: Failed to fetch http://archive.getdeb.net/ubuntu/dists/trusty-getdeb/apps/binary-i386/Packages  521  Origin Down [IP: 104.28.24.125 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
I tried to follow some old answer but it didn't work just because I didn't download from PPA repository but GetDeb. I tried to follow this guide in GetDeb but when I enter sudo apt-get update, the terminal still informs about the same error.
Updated with pastebin the source list
Update with new information when sudo apt-get update, this shows a new error:
W: Duplicate sources.list entry http://archive.getdeb.net/ubuntu/ trusty-getdeb/apps amd64 Packages (/var/lib/apt/lists/archive.getdeb.net_ubuntu_dists_trusty-getdeb_apps_binary-amd64_Packages)
W: Duplicate sources.list entry http://archive.getdeb.net/ubuntu/ trusty-getdeb/apps i386 Packages (/var/lib/apt/lists/archive.getdeb.net_ubuntu_dists_trusty-getdeb_apps_binary-i386_Packages)
W: You may want to run apt-get update to correct these problems
First error:
means that server is down. I tested repository url and it is really down.
Second error that you got means that there are two entries for the same repository.
Check where are defined using these commands:
  grep "archive.getdeb.net/ubuntu/ trusty-getdeb/apps" /etc/apt/sources.list
  grep "archive.getdeb.net/ubuntu/ trusty-getdeb/apps" /etc/apt/sources.list.d/*
If you find out multiple definition, remove duplicated items and redo:
  sudo apt-get update
Today I checked repository url and now it seems up.
Lety
  • 6,089
  • 32
  • 38
