Is there a way for a busy person to be able to put an item on my iCloud Calendar and have the event added to a main KOrganizer calendar automatically, and vice versa?
Here is how I did this, thanks to the advice from @Khurshid_Alam:
- Download an iCloud CloudDav discovery program called
icloudfrom its GitHub page. - Extract
icloud-master/groovy_java/gui-2.0.1.zip. (Be sure to read the README as apparently there are legal issues...) - Run
icloud-master/groovy_java/gui-2.0.1/bin/gui. - Type in Apple ID Credentials and select a server. Any server will work. Click "Get calendar URLs".
- Click the URL on the far right next to the name of the main Calendar, Ctrl+C to copy it.
- In KOrganizer, right click your calendar folder display (by default it is on the bottom left) and select Add Calendar.
- Click "DAV Groupware Resource". Enter in your Apple ID credentials, select the "Configure the resource manually".
- Allow access to the wallet, if the window comes up, and if applicable.
- A new window will come up with "Server configuration" at the bottom. Click "Add" to the right of it, paste the copied URL into the "Remote URL" box, and click "Fetch". When you click "OK", the calendar will be added and automatic uploading and downloading of calendar data will be possible.
- Have fun!
- 8,588
This worked in August 2019:
- Open your Calendar App on iCloud.com or iPhone
Make calendar public to check the direct link to the server. It might looks like these:
https://p15-caldav.icloud.com
https://p16-caldav.icloud.com
etc...
Calendar doesn't need to be public anymore. Make calendar private again if you wish.
- Go to https://appleid.apple.com and generate password for third-party application. Label it as 'KOrganizer'.
- Open KOrganizer, Add Calendar as "DAV Groupware Resource". Enter in your Apple ID, generated password and select the "Configure the resource manually".
- Add url from step 2. This link will add all calendars from icloud. It is possible to sync only selected calendars.
- 21
Right now I can verify that KOrganizer is not sending authorization headers:
See this post on Sync with icloud Caldav
There is a bug open for this, but no action in 6 months:
https://bugs.kde.org/show_bug.cgi?id=434757
- 2,182
- 231
Since this thread is highly ranked on Google, I'll add a new reply despite it being quite old. I've fixed this issue and it should be working with the next release of kdav (presumably > v5.90.0).
The accepted change in KDav - GitLab fixed an error in the usage of the calendar-multiget retrieval As documented in https://datatracker.ietf.org/doc/html/rfc4791#section-7.9 , ics files inside the request are referenced via their relative path. The change corrects this behavior. This is what was preventing KDav from working with iCloud.
- 122,292
- 133
- 301
- 332
