21
On windows OS, when you copy a file into a directory that already has a file with that name, it asks you whether you want to:
  1. copy the file and replace/overwrite the existing one
  2. cancel copying the new file into the directory
  3. copy the file, but rename it (as something like "filename - copy (1)")
When I do this in Ubuntu, I don't have that 3rd option (which is a lot of times a very useful option). Is there any way to be able to do that in Ubuntu?
αғsнιη
  • 36,350
Unfortunately Nautilus doesn't have that option.
Option 1: A different file manager
You could try another file manager like Dolphin.
Install Dolphin (requires the Universe repository)
Option 2: Command-line
You can also use the command line program cp(1) with the backup option:
cp --backup -t DESTINATION SOURCE [SOURCE...]
This has the following effects which can be controlled with other options as described in the manual page of cp(1):
--backup[=CONTROL] ― make a backup of each existing destination file
-b ― like --backup but does not accept an argument
-S, --suffix=SUFFIX ― override the usual backup suffix
The backup suffix is ~, unless set with --suffix or SIMPLE_BACKUP_SUFFIX. The version control method may be selected via the --backup option or through the VERSION_CONTROL environment variable. Here are the values:
  • none, off: never make backups (even if --backup is given)
  • numbered, t: make numbered backups
  • existing, nil: numbered if numbered backups exist, simple otherwise
  • simple, never: always make simple backups
Example
cp --backup=existing --suffix=.orig -t ~/Videos ~/Music/*
This will copy all files in ~/Music to ~/Videos. If a file of the same name exists at the destination, it is renamed according to the following rules:
  • if <FILENAME>.1 exists, use a numbered name to back the original file up, i. e. append a dot (.) followed by the lowest number that doesn't correspond to an existing file,
  • otherwise append the chosen back-up suffix .orig.
Only then is the source file copied to the destination.
If you want to copy files in subdirectories recursively use:
cp -R --backup=existing --suffix=.orig -t ~/Videos ~/Music
David Foerster
  • 36,890
  • 56
  • 97
  • 151
Found this on superuser:
#!/bin/bash
cp -vn "$1" "$2"/ || cp -vn "$1" "$2"/"${1##*/}"~"$(md5sum "$1" | cut -f1 -d' ')"
The file that has the same name gets renamed to the file with the md5sum added to the name. If you save it to a filename like "saveCopy" you can use find like this to execute it:
find . -name 'z*.jpg' -exec ./saveCopy {} /tmp/Extracted/ \;
For more on this see the link.
Rinzwind
  • 309,379
There was a solution (ultracopier) to this question in this forum before: see https://ubuntuforums.org/showthread.php?t=2251859 According to that discussion, it can eb integrated into Nautilus.
Adalbert Hanßen
  • 823
  • 15
  • 31
Copy this script to the top directory, make it executable and run it:
#!/bin/bash
## Get a list of all files
list=$(find . -mindepth 2 -type f -print)
nr=1
## Move all files that are unique
find . -mindepth 2 -type f -print0 | while IFS= read -r -d '' file; do
    mv -n $file ./
done
## Checking which files need to be renamed
while [[ $list != '' ]] ; do
   ##Remaming the un-moved files to unique names and move the renamed files
       current_file=$(basename $file)
       mv -n $file "./${nr}${current_file}"
   done
   ## Incrementing counter to prefix to file name
   nr=$((nr+1))
done
warhansen
  • 230
