I got this output:
fsck from util-linux 2.20.1
e2fsck 1.42.9 (4-Feb-2014)
/dev/mapper/ubuntu--vg-root is mounted.
e2fsck: Cannot continue, aborting.
after I used the fsck command. Any answers?
I got this output:
If you just use fsck to check the volume you can run
fsck -nf /dev/sda1
clean but you can force a new checkIf you want to fix filesystem errors, first unmount your partition: umount /dev/sda1
I don't know why, but I had to service udev stop (on debian based system).
After stopping udev the e2fsck -f /dev/sda1-command worked and didn't print the e2fsck: Cannot continue, aborting-Message anymore.
I dont't know, if it has something to do with http://dev.bizo.com/2012/07/mdadm-device-or-resource-busy.html - but this page gave me the hint to try it.
I encountered similar issue especially when you are still accessing the mount point. It can below any one of below two reasons.
You cannot run on the root FS Say you can in directory "/mnt" and you have unmounted the volume mounted on "/mnt". You will encounter same error. Make use that you are not in same directory.
Before :
root@ip-172-31-28-38 /mnt# fsck -f /dev/xvdh
fsck from util-linux 2.23.2
e2fsck 1.42.12 (29-Aug-2014)
/dev/xvdh is in use.
root@ip-172-31-28-38 /mnt# cd /
After :
root@ip-172-31-28-38 /# fsck -f /dev/xvdh
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/xvdh: 12/524288 files (0.0% non-contiguous), 70287/2097152 blocks
The following solution worked for me:
sudo fsck -f /dev/sda4 replacing 4 with the number you found earlier
-- repeat the fsck command if there were errors --rebootTry the below command this file fix it for you.
resize2fs /dev/sda1
Originally this command is for resizing the partition but it also refreshes the file system and does what you guys want to achieve with the fsck command.
Doesn't work
fsck -f -y /dev/sdd3
smartctl -t short /dev/sda
mount -o remount,rw /
Here's what will help. If you're using Debian installation media, select "Recover a broken system".
lsblk
e2fsck -f /dev/sdaX
Or create a forcefsck file in the / directory:
touch /forcefsck
and reboot the OS
