I'm having a bit of trouble mounting an ZFS pool I've migrated from a FreeNas system to Ubuntu 14.04.
So far I've managed to import the ZFS pool via the zpool import Storage command. I can list all the mount points with the zfs list command. My issue is I don't know how to mount these. Preferably permanently (or on startup).
Any help would be greatly appreciated.
zfs list:
sudo zfs list ⏎
NAME USED AVAIL REFER MOUNTPOINT
Storage 2.10T 3.09T 1.71G /media/Storage
Storage/Others 12.9G 3.09T 232K /media/Storage/Others
Storage/backup_osx 256K 3.09T 256K /media/Storage/backup_osx
Storage/MyStuff 662G 3.09T 662G /media/Storage/MyStuff
Update
So, I managed to sort it out myself. My problem was, that after I had run the zpool import Storage command, my disks wouldn't show up anywhere (nor should they!!!). After you import the ZFS Pool, you need to mount the drives. If you've installed ZFS on Linux then you can run the mountall command and the mountpoints will be mounted in your system.
A bit of trivia
If you take a look at the zfs list i posted, the NAME corresponds to (in my case) the user's drive on the ZFS Raid array. The MOUNTPOINT corresponds to the place where you want your ZFS drive to show up.
So if you run zfs set mountpoint=/media/Storage/Others Storage/Others it will mount the Storage/Others "drive" in your /media/ folder. Note that you will need to mount the parent drive in order for anything to show up. I.e. I would need to mount Storage before being able to mount Storage/Others.
I hope this makes sense, if not, let me know and I will calrify. Also, someone with a bit more knowledge about this subject might find what I've written to be misleading, if so, let me know. This is just the way I understood it.
Also, this thread helped me
