Background: I am installing ubuntu on an SSD. I have two other spinning hard drives in my box as well. One of these contain an older install of ubuntu. For some reason Nautilus doesn't auto mount the file systems on the other drives when I am browsing the file system. Maybe it's because I am already at the partitioning step of the installer.
Question: How can I easily check the contents of the file systems before deciding which partition to mount at which mount point. I would for example like to re-use my old /home partition. I would prefer something that requires less manual work than mounting my partitions manually. Earlier when I've run the installation CD it has somehow been able to mount all my partitions automatically. I figured maybe I could activate this script manually if I knew where it was.
Sam
  • 569
To get a quick information on an unmounted partition's content it may be a good idea to name them with labels. This will give you not only knowlegde on the content but you will also be able to easily mount them by their label name.
To do so either run Gparted, or open Disk Utility from the Das and choose Edit Filesystem Label for labeling of a hard drive or Edit Partition to change the label of a selected partition.
For a command line option and more details on mounting by label see this answer.
Takkat
  • 144,580
