I am currently trying to install software offline (studying this question) and want to use Offline Repository according to this answer.
I followed steps like:
- put all debs in
/var/my-local-repo sudo bash -c 'dpkg-scanpackages /var/my-local-repo /dev/null > /var/my-local-repo/Packages'(note:dpkg-devis already installed to perform this action)- set repository as root by
echo "deb file:/var/my-local-repo ./" > /etc/apt/sources.list.d/my-local.listandsudo apt-get update
But when I tried to install package, following errors display:
Below is example output from terminal while installing synaptic:
$ sudo apt-get install synaptic
Reading package lists... Done
Building dependency tree
The following extra packages will be installed:
docbook-xml libcairo-perl libept1.4.12 libglib-perl libgtk2-perl
libpango-perl librarian0 rarian-compat sgml-data
Suggested packages:
docbook docbook-dsssl docbook-xsl docbook-defguide libfont-freetype-perl
libgtk2-perl-doc perlsgml w3-recs opensp libxml2-utils dwww menu deborphan
tasksel
The following NEW packages will be installed:
libpango-perl librarian0 rarian-compat sgml-data synaptic
0 upgraded, 10 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/3,437 kB of archives.
After this operation, 17.4 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
WARNING: The following packages cannot be authenticated!
libept1.4.12 sgml-data docbook-xml libcairo-perl libglib-perl libpango-perl
libgtk2-perl synaptic librarian0 rarian-compat
Install these packages without verification? [y/N] Y
Err file:/var/my-local-repo/ ./ libept1.4.12 1.0.12
File not found
Err file:/var/my-local-repo/ ./ sgml-data 2.0.9-1
File not found
Err file:/var/my-local-repo/ ./ docbook-xml 4.5-7.2
File not found
Err file:/var/my-local-repo/ ./ libcairo-perl 1.104-1
File not found
Err file:/var/my-local-repo/ ./ libglib-perl 3:1.304-1
File not found
Err file:/var/my-local-repo/ ./ libpango-perl 1.224-2
File not found
Err file:/var/my-local-repo/ ./ libgtk2-perl 2:1.249-2
File not found
Err file:/var/my-local-repo/ ./ synaptic 0.81.1
File not found
Err file:/var/my-local-repo/ ./ librarian0 0.8.1-5ubuntu1
File not found
Err file:/var/my-local-repo/ ./ rarian-compat 0.8.1-5ubuntu1
File not found
E: Failed to fetch file:/var/my-local-repo//var/my-local-repo/libept1.4.12_1.0.12_i386.deb File not found
E: Failed to fetch file:/var/my-local-repo//var/my-local-repo/sgml-data_2.0.9-1_all.deb File not found
E: Failed to fetch file:/var/my-local-repo//var/my-local-repo/docbook-xml_4.5-7.2_all.deb File not found
E: Failed to fetch file:/var/my-local-repo//var/my-local-repo/libcairo-perl_1.104-1_i386.deb File not found
E: Failed to fetch file:/var/my-local-repo//var/my-local-repo/libglib-perl_3%3a1.304-1_i386.deb File not found
E: Failed to fetch file:/var/my-local-repo//var/my-local-repo/libpango-perl_1.224-2_i386.deb File not found
E: Failed to fetch file:/var/my-local-repo//var/my-local-repo/libgtk2-perl_2%3a1.249-2_i386.deb File not found
E: Failed to fetch file:/var/my-local-repo//var/my-local-repo/synaptic_0.81.1_i386.deb File not found
E: Failed to fetch file:/var/my-local-repo//var/my-local-repo/librarian0_0.8.1-5ubuntu1_i386.deb File not found
E: Failed to fetch file:/var/my-local-repo//var/my-local-repo/rarian-compat_0.8.1-5ubuntu1_i386.deb File not found
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Here we can see that apt tries to fetch debs from /var/my-local-repo//var/my-local-repo/ instead of var/my-local-repo/
And if I move all debs into /var/my-local-repo/var/my-local-repo/ (by creating subdirectories) then after apt works fine and package is installed!
And synaptic working fine.
So, My question is Why Apt fetching debs from wrong location or/and What correction is needed in echo "deb file:/var/my-local-repo ./"?
