I will install Ubuntu alongside Windows 7. Will any partition be formated,or things will stay as they are?
Asked
Active
Viewed 77 times
Backup everything before doing any changes, as usual. (Helps a lot if something goes wrong)
You are using Windows 7, so I suppose you will not have troubles regarding secure boot, UEFI etc.
You have several options:
Doing the formatting prior to the installation
Using Ubuntu's auto-formatter
Doing a manual formatting while installing
Personally I use 1 . But Windows cannot resize a partition in use beyond a certain point (usually C:), which is when you have to do the resizing while installing Ubuntu (2. or 3.). If you plan to have several different partitions in a special Layout I recommend 3., but for a beginner I would recommend 2.
