I was working with CUDA5.5, however I wanted to install CUDA6.5 using the main repository given by nvidia.
sudo dpkg -i cuda-repo-ubuntu1404_6.5-14_amd64.deb
sudo apt-get update
But when I try to install cuda I get the following error.
sudo apt-get install cuda
Reading package lists... Done
Building dependency tree
 cuda : Depends: cuda-6-5 (= 6.5-14) but it is not going to be installed
I would appreciate any help.
ssierral
  • 163
Same error message with me, but none of the above answers helped in my case (Ubuntu 14.10). Therefore, first dissect the error message. It says:
cuda : Depends: cuda-6-5 (= 6.5-14) but it is not going to be installed.
So cuda has a dependency cuda-6-5, which can not be installed. Why? Let's check: sudo apt-get install cuda-6-5 produced a similar message to the original one for me saying something like:
cuda-6-5 : Depends: libcudart6.0 (=....) but it is not going to be installed.
So libcudart6.0 is the problem. Let's check why: sudo apt-get install libcudart6.0 results in:
libcudart6.0 : Depends: nvidia-340 (=....) but it is not going to be installed.
So this is the problem: The installed NVIDIA driver (and also those available in the repository) are not recent enough. Adding the xorg-edgers PPA helps:
sudo add-apt-repository ppa:xorg-edgers/ppa
sudo apt-get update
Running the original sudo apt-get install cuda now works.
(This may not be a problem, if one runs the *.run file from the NVIDIA developer website.)
karel
  • 122,292
  • 133
  • 301
  • 332
osdf
  • 171
From the terminal run:
sudo apt-get remove nvidia-cuda-*  # remove old nvidia-cuda packages
sudo apt-get update
Some actions must be taken after installing the CUDA Toolkit and Driver before they can be completely used. Perform the post-installation actions.
Ubuntu 16.04 and later
Open the terminal and type;
sudo apt remove --purge nvidia*
sudo apt remove --purge "nvidia*"
sudo apt remove nvidia-cuda-*
sudo apt install nvidia-cuda-toolkit
Reference: NVIDIA CUDA Getting Started Guide for Linux v6.5
karel
  • 122,292
  • 133
  • 301
  • 332
I had similar problem, for me it helped to make sure all other cuda and libcuda packages are removed.
List them with:
dpkg -l | grep cuda
If the list shows something, remove it with:
sudo apt-get remove <something>
After that install with the usual steps
sudo dpkg -i cuda-repo-<distro>_<version>_<architecture>.deb
sudo apt-get update
Hope it helps.
Hohac
I encountered the same problem when upgrading from Ubuntu 12.04 to 14.04 and CUDA. I tried the above solutions, none of the packages listed was installed.
I solved it by removing nvidia-libopencl-* and nvidia-opencl-* packages.
