I do not have function key / fn for that :( .
Any ideas? Maybe there are settings or commands?
Other subjects were NOT helpful:
  • gpointing-device-settings (auto-disable setting gets unticked);
  • kde-config-touchpad (can not be installed alone);
  • no idea how to useudevd .
Esamo
  • 1,542
Solution - automatic
Thanks to Esamo and his work.
To add AUTO triggers for connecting mouse on startup:
Create the file: /etc/udev/rules.d/10-local.rules
Fill up with this content: (replace $USER with your user name)
ACTION=="add", SUBSYSTEM=="input", KERNEL=="mouse[0-9]", ENV{DISPLAY}=":0",ENV{XAUTHORITY}="/home/$USER/.Xauthority", ENV{ID_CLASS}="mouse", RUN+="/home/$USER/scripts/touchpad_switcher.sh false"
ACTION=="remove", SUBSYSTEM=="input", KERNEL=="mouse[0-9]", ENV{DISPLAY}=":0",ENV{XAUTHORITY}="/home/$USER/.Xauthority", ENV{ID_CLASS}="mouse", RUN+="/home/$USER/scripts/touchpad_switcher.sh true"
Example:
ACTION=="add", SUBSYSTEM=="input", KERNEL=="mouse[0-9]", ENV{DISPLAY}=":0",ENV{XAUTHORITY}="/home/dawid/.Xauthority", ENV{ID_CLASS}="mouse", RUN+="/home/dawid/scripts/touchpad_switcher.sh false"
ACTION=="remove", SUBSYSTEM=="input", KERNEL=="mouse[0-9]", ENV{DISPLAY}=":0",ENV{XAUTHORITY}="/home/dawid/.Xauthority", ENV{ID_CLASS}="mouse", RUN+="/home/dawid/scripts/touchpad_switcher.sh true"
Next place your script wherever you want. I placed it in ~/scripts
#!/bin/sh
enabled=$1
touchpad_id=$(xinput | grep -i "touchpad" | cut -f2 | cut -d '=' -f2);
if $enabled
then
  xinput set-prop $touchpad_id "Device Enabled" 1 | notify-send "The touchpad is now enabled." ""
else
  xinput set-prop $touchpad_id "Device Enabled" 0 | notify-send "Disabling the touchpad..." ""
fi
Remember to add execute permissions:
chmod +x touchpad_switcher.sh
Now simply reboot! ( merely restarting udev doesn't seem to work...)
Some other useful stuff:
Some info about udev rules
Example from ArchLinux
Simlar question
Gelldur
  • 263
SOLUTION - not automatic
The script below, when executed, will disable the touchpad if any mouse is connected and show a notification.
if xinput | grep -i "mouse" | grep -i "pointer"
    then xinput set-prop $touchpad_id "Device Enabled" 0 |
    else xinput set-prop $touchpad_id "Device Enabled" 1 |
fi
Added there also a reverse situation, although in my case the touchpad gets enabled on mouse disconnection anyway. I have saved the script in a file and am running it from Unity Launcher Terminal section after every mouse plug in.
ADVANCED
  1. More mouses?
    Clarify which mouse should deactivate the touchpad by expanding the value in "mouse" fragment, name based on xinput devices list.
  2. Scared mouse runs from edge to edge?
    I had to run additional command for mouse - decreasing cursor acceleration since it is madly set to 10 on every connection. Actually after a while I made auto-detection script (it gets mouse id and its' prop for velocity; dunno about performance of cut)...
    mouse_id=$(xinput | grep -i "mouse" | grep -i 'pointer' | cut -f2 | cut -d '=' -f2);
    mouse_prop=$(xinput list-props $mouse_id | grep -i "velocity" | cut -f2 | cut -d '(' -f2 | cut -d ')' -f1 );
             xinput set-prop $mouse_id $mouse_prop 3 |
    fi
Learned a lot today to make above :D .
SOMEONE PRO?
  1. Would be useful to know how to make it automatic.
  2. Also curious why mouse config is not saved (2.).
Esamo
  • 1,542
What @David Drozd posted didn't work for me on Ubuntu 16.04.
Seems like the trick with xinput don't work in udev. Only synclient TouchpadOff=[0|1] worked. Also ACTION="remove" didn't work solely.
I finally got it when added ENV{REMOVE_CMD}="/bin/sh -c '/usr/bin/synclient TouchpadOff=0'"
The full solution: create the file /etc/udev/rules.d/10-local.rules with the following line (replace $USER with your user name)
ACTION=="add", SUBSYSTEM=="input", KERNEL=="mouse[0-9]", ENV{DISPLAY}=":0",ENV{XAUTHORITY}="/home/$USER/.Xauthority", ENV{REMOVE_CMD}="/bin/sh -c '/usr/bin/synclient TouchpadOff=0'", RUN+="/bin/sh -c '/usr/bin/synclient TouchpadOff=1' "
