I know how to normalize a song to 100%, but I'd like this to happen automatically before copying the files on my iPod, via Rhythmbox.
So, I imagine a process like this:
  • create my own playlist
  • when clicking Sync button, the songs will be copied in a temp directory
  • they will be normalized to 100% there
  • finally they will be copied to my iPod
Is there a plugin for that? How can I do this?
I want this, because the max volume for iPods is pretty low.
Ionică Bizău
  • 9,803
  • 25
  • 89
  • 129
You can use inotify which is a folder monitoring software: it launch a command when a file is created . Here, it will launch mp3gain . To set up :
  1. Install
sudo apt-get install inotify-tools incron mp3gain
  1. edit incron.allow
sudo gedit /etc/incron.allow
then add your username , save , you may reboot (not sure but ...)
  1. Choose or create a folder where sound files will be copied and then normalized
    (Here I create a new folder "normalize" in my home dir. but you may use existing folder be on your usb device,
    something like /media/ipod/music)
mkdir ~/normalize
  1. Run incrontab -e and copy this line in the editor (replace 2 "username" with your login ) :
    /home/username/normalize IN_CREATE /home/username/normalize.bash $@/$#
    Save and close editor .
    This set the monitored folder and the command executed when a file is created in (command is normalize.bash ).
(If you have problem with default editor , you can change it to pico (gedit don't work for me) : Run this before incrontab -e : export EDITOR=pico )
  1. Create a new file normalize.bash containing this :
#!/bin/bash
PATH1=/home/username/normalize
echo "***********************************************************"  >> ~/normalize.log
 date >> ~/normalize.log
#get extension to exit on TMP files
filename=$(basename "$1")
extension="${filename##*.}"
if [[ "$extension" = "TMP" ]]
 then
echo TMP exit>> ~/normalize.log
 exit
 fi
# do normalize
/usr/bin/mp3gain -c -r "$1"   >> ~/normalize.log
#END
In second line change PATH1 to the previously created/existing folder. Save as normalize.bash in your home.
Now, when a file is created in the folder "normalize", mp3gain will run (actions are logged in normalized.log file in home dir)
laugeo
  • 2,880
  • 14
