I am using 32-bit Ubuntu 14.04 LTS on my simple Desktop-PC (3GHz Intel P4, 1GB RAM, Intel inbuilt Graphics, and NO extra graphic-card) so nothing to worry about graphic like nvidia etc.
Here is output of lspci:
$ lspci
00:00.0 Host bridge: Intel Corporation 82945G/GZ/P/PL Memory Controller Hub (rev 02)
00:02.0 VGA compatible controller: Intel Corporation 82945G/GZ Integrated Graphics Controller (rev 02)
00:1b.0 Audio device: Intel Corporation NM10/ICH7 Family High Definition Audio Controller (rev 01)
00:1c.0 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 1 (rev 01)
00:1c.1 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 2 (rev 01)
00:1c.2 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 3 (rev 01)
00:1c.3 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 4 (rev 01)
00:1d.0 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #1 (rev 01)
00:1d.1 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #2 (rev 01)
00:1d.2 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #3 (rev 01)
00:1d.3 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #4 (rev 01)
00:1d.7 USB controller: Intel Corporation NM10/ICH7 Family USB2 EHCI Controller (rev 01)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev e1)
00:1f.0 ISA bridge: Intel Corporation 82801GB/GR (ICH7 Family) LPC Interface Bridge (rev 01)
00:1f.1 IDE interface: Intel Corporation 82801G (ICH7 Family) IDE Controller (rev 01)
00:1f.2 IDE interface: Intel Corporation NM10/ICH7 Family SATA Controller [IDE mode] (rev 01)
00:1f.3 SMBus: Intel Corporation NM10/ICH7 Family SMBus Controller (rev 01)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 01)
I've installed xubuntu-desktop environment, unity-tweak-tool which are working fine for 3 month.
Recently I faced problem : Unity doesn't load, no Launcher, no Dash appears. I've tried the answers, but unable to solve my problem.
Probable reason for this is I've installed ubuntu-tweak recently. So, Also I removed it from tty, but unable to solve this problem.
I have Three ways to do anything:
  1. Using tty (Ctrl+AltF1)
  2. I've installed nautilus-open-terminal so I am able to start gnome-terminal by right-click on desktop and "Open Terminal Here".
  3. Using Xubuntu Session.
I have tried following things:
  • Enabling unity-plugin (https://askubuntu.com/a/76951/256099) But not solved.
  • dconf reset -f /org/compiz/ from gnome-terminal
  • Purged and re-installed unity, compiz and ubuntu-desktop
  • Removed cache by rm -rf ~/.compiz-1 ~/.config/compiz-1, sudo rm -fr ~/.compiz, sudo rm -fr ~/.cache/* ,sudo rm -fr .cache/*
  • Trying to replace/reset unity by following from gnome-terminal:
    1. unity --replace
    2. setsid unity
    3. ubuntu-tweak-tool --reset-unity
Output-1, Output-2
All shows common thing:
compiz (core) - Info: Starting plugin: unityshell
WARN  2014-10-02 12:11:25 unity.glib.dbus.server GLibDBusServer.cpp:579 Can't register object 'org.gnome.Shell' yet as we don't have a connection, waiting for it...
ERROR 2014-10-02 12:11:25 unity.debug.interface DebugDBusInterface.cpp:196 Unable to load entry point in libxpathselect: libxpathselect.so.1.4: cannot open shared object file: No such file or directory
WARN  2014-10-02 12:11:25 xim.controller XIMController.cpp:103 IBus natively supported.
ERROR 2014-10-02 12:11:26 nux.gltexture.resource.manager GLTextureResourceManager.cpp:54 Invalid target, impossible to generate a new texture. Impossible to generate a pixbuf: Failed to open file '': No such file or directory
WARN  2014-10-02 12:11:26 unity.glib.dbus.server GLibDBusServer.cpp:579 Can't register object 'com.canonical.Unity.Launcher' yet as we don't have a connection, waiting for it...
WARN  2014-10-02 12:11:26 unity.glib.dbus.server GLibDBusServer.cpp:579 Can't register object 'com.canonical.Unity.Dash' yet as we don't have a connection, waiting for it...
WARN  2014-10-02 12:11:26 unity.glib.dbus.server GLibDBusServer.cpp:579 Can't register object 'org.gnome.SessionManager.EndSessionDialog' yet as we don't have a connection, waiting for it...
WARN  2014-10-02 12:11:26 unity.glib.dbus.server GLibDBusServer.cpp:579 Can't register object 'com.canonical.Unity.Session' yet as we don't have a connection, waiting for it...
WARN  2014-10-02 12:11:26 unity.glib.dbus.server GLibDBusServer.cpp:579 Can't register object 'org.gnome.ScreenSaver' yet as we don't have a connection, waiting for it...
Segmentation fault (core dumped)
I've could try a re-install of whole OS. Or, is there any way to solve this problem?
Now what to do? (Isn't it possible to re-install whole unity desktop environment and use fresh D.E. without such problem?)
Pandya
  • 37,289
Try to:
Restore default settings
Execute the following commands in terminal, one at time.
gconftool --shutdown
sudo killall -r -I gconf
sudo killall -r -I dconf
rm -rf .compiz* .gconf* .config/dconf/ .config/compiz*
Be aware that above commands will remove any settings or configuration you've done already. Keyboard layouts (if any) will also be removed. Although above commands will not delete any files, they will restore Unity settings as were, when you installed Ubuntu for the first time.
Reboot your system for changes to take effect.
The same thing happened to me one time, so here's the answer I got that worked.
αғsнιη
  • 36,350
