Possible Duplicate:
How to disable X at boot time?
The title says it all really.
I've got Xubuntu 11.04 working as a file server which I SSH into. 90% of the time it's headless and therefore requires no GUI. I don't want to install just a bare server however because there are times when I want the graphical environment.
How do I best do this? I've already set GRUB_DEFAULT=1 in /etc/default/grub but this is doesn't do what I want as I then drop into an ncurses style menu prior to getting a prompt.
I want a normal console.
boehj
  • 2,091
In the file /etc/default/grub make sure that the line starting with GRUB_CMDLINE_LINUX= contains the word "text", e.g. GRUB_CMDLINE_LINUX="nosplash text". Then run update-grub. When you reboot, you should go to a login prompt. I've had my home server set up this way for a couple of years.
P.S. Have you looked at Webmin to administer your server? It's great.
Paul H.
  • 264
