I keep hitting the Insert key accidentally and it really annoys me.
Is there any way to disable it's default behavior, toggling insert/overwrite mode in editors?
Go to Keyboard Shortcuts in System settings, then press Add button and insert a Name of your choice, say "DisableIns", and true as a harmless command then press Apply button.
Now, in the Custom Shortcuts section you will find an entry
DisableIns | Disabled
Click on Disabled, then perform your custom shortcut Ins. Press close, you're done.
I'm not sure it is the "right" way, but in my tests I could disable the behaviour of Insert using the following command:
$ xmodmap -e "keycode 118 ="
If this works for you, you could put the assignment in a file ~/.Xmodmap, i.e.
keycode 118 =
which should be loaded automatically at login. See questions here and here for more information about local xmodmap configuration.
Type sudo nautilus in Terminal. Then go to /usr/share/X11/xkb/symbols and open pc. Then change this line:
key <INS> { [ Insert ] };
to
key <INS> { [ XF86Send ] };// Insert
Then run this:
sudo dpkg-reconfigure xkb-data
in Terminal and restart Ubuntu.
This will replace Insert with Send. You can replace it with any other appropriate key. To see a list of keys run this:
xmodmap -pke
Note: A mistake in editing pc. eg inserting an inappropriate character, may corrupt Ubuntu.
