So I am running Ubuntu Studio on my laptop and what do I do to connect to a proxy? I search for proxy and in network settings their is no PROXY tab. What are key words in the tabs to look for?
Eliah Kagan
  • 119,640
iiLezso
I wrote a script in response to a question at Unix & Linux about setting proxies:
#! /bin/bash
HTTP_PROXY_HOST="proxy.example.com"
HTTP_PROXY_PORT=3128
HTTPS_PROXY_HOST="proxy.example.com"
HTTPS_PROXY_PORT=3128
gsettings set org.gnome.system.proxy mode manual
gsettings set org.gnome.system.proxy.http host "$HTTP_PROXY_HOST"
gsettings set org.gnome.system.proxy.http port "$HTTP_PROXY_PORT"
gsettings set org.gnome.system.proxy.https host "$HTTPS_PROXY_HOST"
gsettings set org.gnome.system.proxy.https port "$HTTPS_PROXY_PORT"
sudo sed -i.bak '/http[s]::proxy/Id' /etc/apt/apt.conf
sudo tee -a /etc/apt/apt.conf <<EOF
Acquire::http::proxy "http://$HTTP_PROXY_HOST:$HTTP_PROXY_PORT/";
Acquire::https::proxy "http://$HTTPS_PROXY_HOST:$HTTPS_PROXY_PORT/";
EOF
sudo sed -i.bak '/http[s]_proxy/Id' /etc/environment
sudo tee -a /etc/environment <<EOF
http_proxy="http://$HTTP_PROXY_HOST:$HTTP_PROXY_PORT/"
https_proxy="http://$HTTPS_PROXY_HOST:$HTTPS_PROXY_PORT/"
EOF
Save to a file (call it proxy.sh), edit it using your favourite editor to set the values of the *_PROXY_* variables and run:
chmod +x proxy.sh
./proxy.sh
It does, as far as I am aware, exactly what the GUI does (if based on a GNOME environment, which Ubuntu Studio is).
muru
  • 207,228
You can set your proxy via the terminal.
You should, for that, edit the following files:
/etc/bash.bashrc
/etc/environment
/etc/apt/apt.conf
/usr/local/etc/freshclam.conf
These files must have the following contents:
    sudo -i
    nano  /etc/bash.bashrc
    export http_proxy=http://username:password@proxyserver.net:port/
    export https_proxy=http://username:password@proxyserver.net:port/
    export ftp_proxy=http://username:password@proxyserver.net:port/
Control + O, save file.
    sudo -i
    nano  /etc/environment
    sudo -i
    nano /etc/apt/apt.conf
    Acquire::http::Proxy "http://username:password@proxyserver.net:port";
    Acquire::https::Proxy "http://username:password@proxyserver.net:port";
    Acquire::ftp::Proxy "http://username:password@proxyserver.net:port";
    sudo -i
    nano  /usr/local/etc/freshclam.conf
    HTTPProxyServer proxyserver.net
    HTTPProxyPort port
    HTTPProxyUsername username
    HTTPProxyPassword password
Control + O, save file. Control + X, close nano
muru
  • 207,228
kyodake
  • 17,808
