I want to set the proxy for apt-get and the global proxy in xubuntu like here but with only one command. How would it be? What's the problem with this code? I save it in ~/.functions add the line . ~/.functions to the .bashrc file and when I reload the .bashrc file gives an error about EOF in line 7.
Correct code:
myproxy="http://proxy.server:port/"
proxyhost="proxy.server"
myport=port
# Set Proxy
function setproxy() {
    sudo tee -a /etc/environment << EOF
    http_proxy="$myproxy"
    https_proxy="$myproxy"
    ftp_proxy="$myproxy"
    no_proxy="localhost,127.0.0.1,localaddress,.localdomain.com"
    HTTP_PROXY="$myproxy"
    HTTPS_PROXY="$myproxy"
    FTP_PROXY="$myproxy"
    NO_PROXY="localhost,127.0.0.1,localaddress,.localdomain.com"
EOF
    gsettings set org.gnome.system.proxy mode manual
    gsettings set org.gnome.system.proxy.http host "$proxyhost"
    gsettings set org.gnome.system.proxy.http port "$myport"
    gsettings set org.gnome.system.proxy.https host "$proxyhost"
    gsettings set org.gnome.system.proxy.https port "$myport"
    sudo tee /etc/apt/apt.conf.d/95proxies << EOF
    Acquire::http::proxy "http://$proxyhost:$myport/";
    Acquire::ftp::proxy "ftp://$proxyhost:$myport/";
    Acquire::https::proxy "https://$proxyhost:$myport/";
EOF
#Unset Proxy
function unsetproxy() {
    sudo rm /etc/environment
    sudo tee /etc/environment << EOF
    PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games"
EOF
    gsettings set org.gnome.system.proxy mode none
    sudo rm /etc/apt/apt.conf.d/95proxies
You can not set a global environmental variable like http_proxy without at least restarting the shell. You can do one of three things:
  1. Set variable for bash session and run your internet application from bash. http_proxy=8.8.8.8 ftp_proxy=8.8.8.8 firefox
  2. Set variable in DE, if it supports, and start application in DE.
  3. Set variable for user or system-wide and restart bash or relogin. http_proxy=8.8.8.8 ftp_proxy=8.8.8.8 bash firefox exit
Any one can be accomplished by a script, that is started as one command, but clarify first, what do you need?
When you use heredocs, the heredoc limit string (EOF here) at the end should be by itself on that line - nothing else, no spaces, indentation, etc. Therefore your code should look like this:
EOF
muru
  • 207,228
